2003 C230 Mass Airflow sensor - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-13-2009, 03:15 PM Thread Starter
Hi, guy
I have a problem with MAF, but don't know how to remove it, it's different from other class, please help and post up some pictures if posible, will greatful thanks.
elviesjo is offline
post #2 of 3 (permalink) Old 10-13-2009, 05:08 PM
Date registered: Jul 2007
Vehicle: 2001 C320
Here are some pics I took when I replaced the MAF in my 2001 C320. Not sure if it is the same as yours or not. Sorry I don't have a list of the tools I used in the process.
They go in order. In the second picture the MAF is the round black piece towards the back of the engine. There is a clip that goes around it which needs to be removed as well as a plug on the drivers side the unclips. Once both those are removed it pulls right out. Put the new in, attach clip and plug and you're done.
csaunder is offline
post #3 of 3 (permalink) Old 10-13-2009, 06:52 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
It's a similar design to the V6 posted by csaunder, follow back from the air filter and you'll find it. Clips and a clamp, not too difficult.
Be sure to get an OEM Bosch unit, none of those cheapo ebay things or you'll be worse off.
BTW, please take a minute to click user cp and add your vehicle and location to your profile as that is often useful information. You might even find that you're close to another member who'd be willing to give you a hand from time to time.
Check Codes is offline
    Mass Air Flow Sensor cleaning! ksmack1940 R129 SL-Class 83 07-15-2010 09:20 PM
    2003 C230 Kompressor Mass Air Sensor judyeray For Sale/Wanted/Trade/Giveaway 1 10-30-2009 04:10 PM
    Mass Airflow Sensor Klaus9000 General AMG 8 05-15-2009 02:11 PM
    New MASS AIRFLOW SENSOR MAF AIR MASS METER $1 97e320auto For Sale/Wanted/Trade/Giveaway 2 04-22-2006 04:56 PM
    Mass airflow sensor in C230 samgupta General Mercedes-Benz 2 12-29-2005 07:39 AM
