wheel bearing replacement - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-11-2009, 08:04 PM Thread Starter
Date registered: Oct 2008
We have a very loud noise coming from the driver side ( the side she ran off the road). I'm thinking that it may not be a bad idea to replace wheel bearing. Any write ups out there? Is there a haynes/chilton equivalent I might could buy?
thanks
bigstinger is offline
post #2 of 4 (permalink) Old 10-11-2009, 10:03 PM
pdorion1986's Avatar
Date registered: Jan 2008
Quoted: 4 Post(s)
there's a hayes and chilton available. try searching on google.
question: i was just about to make a new thread like this. how do i know which part is broken? wheel bearing or hub? i can give specific info if you need. for now my car 101% sure needs the wheel bearing or hub or rotor replaced.
pdorion1986 is offline
post #3 of 4 (permalink) Old 10-12-2009, 06:28 PM
Quoted: 4 Post(s)
post #4 of 4 (permalink) Old 11-27-2009, 12:57 PM
Date registered: Mar 2009
if your wheel bearings are destroyed you will get a lot of squeakiness... if this is happening stop driving your car and get it into the shop... when the bearings finally go they are going to start coming out of the races and they will probably collect inside your dust cap... this is extremely bad as the only thing that holds your hub to the spindle/axle is the wheel bearings themselves. You have two sets of bearings, inner and outer. Replace both of them at the same time if you do replace either. You are going to want/need a hydraulic press to get the races into the spindle.. and night mare enough is that the stock bearing races are flush with the spindle so they are going to be near impossible to get out. Tell you what... I'll take pictures of the whole thing later tonight as I am currently in the process of dealing with all of this jazz right now. I drive a c230k sport coupe 2002. The autozone bearings i picked up are actually OEM (timken) which is stamped on the original bearings. but the bearings autozone suggested do not fit appropriately... i'm currently in the process of finding the right sized bearings right now.
Alternatively, if your hub was cracked you would be having similar issues and similar repair but you probably could determine if it was cracked by just taking the wheel/caliper/caliper holder/rotor off and then just giving it a through inspection.
In the advanced version of bearing failure you will get smoke from the friction of broken bearings, an almost shooting noise when the bearings are expelled from the tire, and when enough bearings are gone you will get lots of vibration as the hub is no longer supported. Final symptom (especially at highway speeds), include the hub ripping from the spindle which may take the wheel, rotor, brakes, and remaining bearings with it, this would almost certainly rip the whole spindle off the car snapping the brake lines and nullifying your brake pedal. Your car would dip immediately towards the missing wheel and you will lose all steering, sliding into whatever gets you to finally stop. Those bearings are very serious business.
Tremere is offline
    Front Wheel bearing replacement jchumba W210 E-Class 98 04-20-2015 05:06 PM
    Wheel bearing replacement sak384 W210 E-Class 1 06-14-2009 06:54 PM
    Wheel Bearing Replacement, need help. skyfreedom W163 M-Class 4 09-13-2007 02:51 AM
    wheel bearing replacement hudson77 G-Class 1 02-11-2006 04:36 AM
    Got stuck doing my wheel bearing replacement... AlanMcR G-Class 15 06-30-2005 11:58 AM
