| Radiator fan always on
Hi fellow benz owners! ive scoured these forums looking for similar issues but havent found any posts which address my issue. when i start the car, the rad fan turns on and stays on until the car is shut off. ive had 2 malfunction messages " washer low" , and " coolant level low". ive checked both and the levels are fine. the engine temp had never moved above 90 degrees celsius so i know the motor is not overheating. the check engine light has come on and my mechanic told me its due to an altitude sensor. im assuming the fan is turning on due to the low coolant warning but after resetting the malfunction warnings the fan still starts. bieng a benz noob and not a mechanic, can anyone shed some light on my situation before i shell out cash to a mechanic? thx!
