Rough Idle After Sitting for Few Days - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-05-2009, 01:08 PM Thread Starter
Date registered: Jun 2009
Vehicle: 2006 C230 Sport
I have noticed that after our C230 sits for a couple of days without being started say from Friday afternoon until Monday morning upon start up the car seems to idle a little rough and almost feels like it has a miss. Also, there is a gurguling sound coming out of the exhaust. After about 10 or 15 seconds everything smooths out and runs fine. Is this common with other 2006 C230's? Before i got alarmed I wanted to check. I did a seach but didn't find anything specifically the same. I have also noticed that on start up from an overnight sit, the engine makes a noise alsmost like a "Knock" for about 2 seconds. I figure that is just from the oil being in the pan and the engine being cold.
Anyone experience anything similar?
Thanks!
DMensik is offline
post #2 of 7 (permalink) Old 08-05-2009, 06:43 PM
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
You guessed it. Both issues you are experiencing are caused by this. Nothing to worry about really.
2002 C32 AMG Sedan [111,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | LET 185MM & ECU | TVT Thermostat | PSK Belt Wrap | CM30
DIY Intercooler Isolation | 26x7x2 FB H/E | Intercooler Reservoir | Battery Relocation | Lorinser Sides
2002c230 is offline
post #3 of 7 (permalink) Old 08-06-2009, 02:12 PM Thread Starter
Ok, thanks. With the sound out of the exhaust sounding like a miss just wanted to make sure other people have experienced the same after prolonged sitting of the car without being started. It felt like and issue had with a car that had a leaking head gasket and would miss until the coolant burned off.
Thanks!
DMensik is offline
post #4 of 7 (permalink) Old 08-06-2009, 04:54 PM
Vehicle: 2005 C230K sport coupe
What is the milage on the car. The M271 engine has a history of the timing chain streching around 60K miles. The knocking sound could be the chain ratteling untill the tensioner can catch up. The tensioner works on oil pressure. I have this on my '05 Coupe, I'm waiting to have the chain replaced in the next week or two.
DaveWA is offline
post #5 of 7 (permalink) Old 08-07-2009, 03:08 PM Thread Starter
The car has only 38K miles on it. I hope I don't have to worry about the chain being stretched this early in the game.
DMensik is offline
post #6 of 7 (permalink) Old 08-07-2009, 06:07 PM
No, I think you can rule out that possibility at such low milage. I don't have any other suggestions at this time. I haven't heard of the head gaskets being a problem on these engines. At 38K I would suspect an electrical malfunction causing the miss but that will usually set a code.
DaveWA is offline
post #7 of 7 (permalink) Old 08-08-2009, 09:37 AM Thread Starter
I think I'll just keep an eye on it. Warranty is up in December so I have a little time if I think it is a problem to get it looked at. We are going on vacation Monday so the car will sit for 6 days without being started, I'll see how it acts.
DMensik is offline
260e rough start/rough idle/shudder CaprezMercedes W124 E,CE,D,TD Class 14 05-25-2010 01:36 PM
HELP! Found 1 wheel sitting in the wheel well after 3 days of no driving K-A W220 S-Class 2 07-02-2008 03:51 AM
Loosing my MIND!!! Battery dead after 3 days of sitting. billabongo W220 S-Class 11 05-03-2008 12:47 PM
Engine Noise after sitting a couple days charris R170 SLK-Class 7 08-22-2004 06:58 PM
rough idle only when cold sitting all day mr diesel W123 E,CE,D,CD,TD,TE Class 6 07-24-2004 06:05 PM
