Brake Rotors and Pads - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 06-17-2009, 02:21 PM Thread Starter
Date registered: Oct 2007
Just recently got myself a 2006 C230 Sport.
Drove it for about 3 weeks and brakes are starting to squeak on the fronts. I've looked it up and are considering either Hawk HPS or Hawk Ceramics. What rotors does everyone usually go after?
On the vehicle are Cross drilled Rotors. I was thinking of going either Brembo Slotted or EBC dimpled and slotted. I've read somewhere here that the stocks are zimmerman Cross drilled? Better to go one these or back to zimmerman?
Thanks
The UnknownAce
UnknownAce is offline
post #2 of 19 (permalink) Old 06-18-2009, 01:34 PM
sd300td's Avatar
Date registered: Dec 2008
Quoted: 10 Post(s)
OEM. It'll be difficult getting anything better without spending another arm and a leg. The vehicle already has plenty of brakes for its HP and weight.
2005 230 K, 26k-77k (sold)
1982 300 TD, 167k-226k
1982 240 D, 308k-327k (sold)
1998 E 320, 120K-141K
sd300td is offline
post #3 of 19 (permalink) Old 06-18-2009, 03:34 PM
Vehicle: 2004 C230 Kompressor Sport Coupe
... but the ceramic pads will keep the wheels easier to clean. Agreed on discs, the stock units provide lots of grab. Anything else will basically just be for looks.
zeet is offline
post #4 of 19 (permalink) Old 06-18-2009, 03:49 PM
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 2002 C32 AMG
Well, the EBC rotors are not expensive, and I was satisfied with them... I agree sticking with OEM might be the best way though.
2002 C32 AMG Sedan [111,000 Miles]
Clear Side Markers | CL Style Grille | Flat Emblem | CF Front Lip Spoiler | CF Rear Diffuser | CF Trunk Spoiler
K&N Air Filters | NGK IX (2 Step) | KV-85 | LET 185MM & ECU | TVT Thermostat | PSK Belt Wrap | CM30
DIY Intercooler Isolation | 26x7x2 FB H/E | Intercooler Reservoir | Battery Relocation | Lorinser Sides
2002c230 is offline
post #5 of 19 (permalink) Old 06-18-2009, 04:04 PM
sd300td's Avatar
Quoted: 10 Post(s)
True. Thankfully c class 5-spoke wheels are super easy to clean
sd300td is offline
post #6 of 19 (permalink) Old 06-20-2009, 12:43 AM Thread Starter
well, my logic for looking at the brembo's/ebc is that since i've decided on getting some hawk pads. either hps or ceramic, typically they are best matched with power slot rotors.
HOWEVER powerslot does not have rotors meant for my 06 C230 w/ sport package.
Does anyone know what the factory disc size is? I guess i could just take off the wheel and measure the disc but i figure if someone knew off hand, then it saves me from doing the extra legwork.
Now i've looked at the Brembo Slotted and those are 300mm or 11.8 inches. BUT the EBC's are 330mm or 13 inches. Which is the correct size for my C?
Thanks
The UnknownAce
post #7 of 19 (permalink) Old 06-21-2009, 12:23 PM
Date registered: Nov 2007
Vehicle: 2012 C300 4Matic
Just don't use aftermarket pads with the OEM rotors. The OEM rotors and pads are made out of specific matching materials.
I also really doubt you're going to get better braking performance (other than brake dust!) with ANY aftermarket rotors / pads short of getting larger calipers. The MB friction materials are amazing. I know this from experience - wasted almost $100 on new brake pads only to go back to stock after a week. The insane amounts of dust are worth it, as much as it sucks.
acr2001 is offline
post #8 of 19 (permalink) Old 06-22-2009, 12:24 PM
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup and 2006 ML350
Quoted: 13 Post(s)
Bull.
Ceramic pads and stock rotors work fine.
You just may end up replacing them at the end of the life of the pads, which is easily 2-3x that of the stock pads which are absolute crap. I was getting 20K-30K miles a set, and
now I have almost 50K on the Akebono's, which still work great, and maybe 1/2 left.
2006 ML350 - Stock
2002 C7 Evolution Orion Blue 2.3L C230 Coupe
Auto-Pano-Oyster Leather-Audio 10
AMG Front bar 22mm-17" Wheels- C32 Brakes- H&R 19mm rear sway
TEIN SS Coilovers -
Clear sides- 2005 tails, Blinkers & Grill- Tinted Windows
Bi-Xenons-Clear Fogs- Clear Side/Stealth Bulbs
C230 Sport Coup is offline
post #9 of 19 (permalink) Old 06-22-2009, 09:34 PM
2002c230's Avatar
C230 Sport is right. Ceramic pads wear the rotors a lot slower, and of course the pads themselves wear slower. You might have less stopping power with ceramic depending on the manufacturers specific material. In general the less dust they produce, the less stopping power you will have, or so it seems.
2002c230 is offline
post #10 of 19 (permalink) Old 06-23-2009, 12:57 PM
Date registered: Jun 2008
Vehicle: 2005 C230 Kompressor Sport Sedan
I'd rather start breaking earlier, than sweating my a** off cleaning my brake dust every week in the florida sun...haha
I think i am gonna go with ceramic pads next time
Meltdbutta is offline
Brake rotors/pads Godiva W210 E-Class 36 01-30-2009 02:51 PM
Brake Pads and Rotors lanabron General Mercedes-Benz 10 07-25-2008 08:57 AM
QUESTION on my recently installed Brake Rotors, Pads, Brake Lines, Brake Flush babyboigsxr C208/A208 CLK-Class 5 03-28-2008 10:37 AM
Brake Rotors, and pads Kerr G-Class 1 07-21-2006 07:13 AM
Brake Pads/Rotors Guest (MBNZ) W210 E-Class 2 02-14-2002 10:38 AM
