ŧ Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-13-2009, 01:24 AM   #1 (permalink)
KompressorKid's Avatar
Date registered: Apr 2007
Vehicle: '00 Ml320 & '02 C230K
DIY Sunroof motor
Well after living with an inoperational sunroof for over a year, I've decided I want it fixed. I was able to score a replacement motor off eBay. Does anyone know of a DIY to get the headliner off only at the front edge to get enough clearance to undo the motor screws? Has anyone tried this? Any help would be appreciated. Thanks.
KompressorKid is offline   Reply With Quote
Old 06-13-2009, 04:36 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 1992 300CE
Which motor did you get? Do you have to solder it on? I need a new motor for my antenna but dont know which one to get. I opened up the unit and found out the motor can be easily replaced by basic soldering skills given it's the right motor. LMK
1992 300CE
BilsteinSport
Vogtland
EuroLampsAllAround
2pc18"///AMGs & YokohamaS.Drives
FS: 5x112 15mm High Quality Spacers
FS/FT: 17" Staggered AMG 5-Spoke CLK Wheels and Tires
FS/FT: 18" Brabus Monoblock IV, 2pc
ronald7410 is offline   Reply With Quote
Old 06-13-2009, 06:50 PM   #3 (permalink)
Eesjunin's Avatar
Vehicle: 2002 Mercedes C320
dont all parts have mb part number on it? i took apart my seat and the motor that operates the backrest has an MB number right on it.
Kkid:
sorry no help with that one, but i can take a look at the repair manual on monday. i pretty much doubt it though. G'luck
...pRoject in pRogreSS...
WTB: AMG skirts
Helpful links:
W203 Seat module fix http://www.benzworld.org/forums/w203-c-class/1403233-diy-how-fix-your-power-seat.html
Mechanic search: http://www.cartalk.com/content/mechx/find.html
HID kits: http://www.tspny.com/shop
Eesjunin is offline   Reply With Quote
Old 07-03-2009, 11:21 AM   #4 (permalink)
Success!!!!!
Well gents I have completed the job and glad to say successful. Here are a couple of thing I learned and will pass on so no others will get jammed.
1. The interior grab handle removal was a bit tricky for me. When pulling the 2 clips, just lift them away from the assembly with a flat blade screwdriver by about 1mm. Then use the same screwdriver to pry them out on the sides, no broken tabs. Don't need to remove both sides.
2. The source of my jam was the wind deflector arms, they caused the assembly to jam and thus strip the gear on the sunroof motor. Each deflector arm is held in place by a single screw on the body and a c-clip on the deflector. Simply remove and use 3M double sided tape to keep the deflector from jumping around when the sunroof is in use.
3. The a-pillar is not the easiest to remove, you will likely break a clip or two (as I did) but in the end it still works.
I had called the stealers previously and was quote $400 for the motor alone, but a quick check on ebay landed the needed part for only $100.
Photo DIY: Removing Sunroof Liner bobs W140 S-Class 12 10-22-2009 07:04 AM
sunroof motor Turnpike W201 190 Class 1 07-29-2008 02:31 AM
Sunroof Rattle DIY vip W163 M-Class 0 08-15-2007 06:06 PM
Sunroof motor tikallinn W210 E-Class 6 04-30-2007 07:31 PM
sunroof gets stuck and won't open. DIY repair? ProV1x W210 E-Class 10 01-31-2007 10:12 AM
