W 203 Gear knob steering,wheel change, clutch nosie ? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-06-2009, 10:03 PM Thread Starter
Date registered: Apr 2009
Vehicle: 2004 w203 Kompressor 200 K Manual trans
Hey I have a w203 manual trans
I need a few inputs on the foll;-
1) How do I remove the gear stick knob?
2) The AC vents
3) The steering wheel
Also when I release the clutch in first or second gear I kinda get a lotta noise from the engine, this noise reduces if I release the clutch reaaaaaaaaaly slowly. Is this because of worn clutch plates or a bad spark plug, pse shed some light?
Ive done about 32 K in the harshest conditions in India.
Many thanks
DJR
Daylyn R is offline
post #2 of 4 (permalink) Old 06-06-2009, 11:14 PM
Vehicle: 2004 C230 Kompressor Sport Coupe
Pull up the boot first and it'll be obvious how to remove the knob. The boot is just clipped around.
The center stack removal instructions are here: COMAND APS Retrofit - Facelift C and CLK Class (W203, W209)
The steering wheel is removed with a long Torx from the backside to remove the airbag, then it is a splined shaft. Do not use the steering wheel lock to hold it in place while you undo the nut!
Noise could be a bad clutch or a bad thrust bearing. Does it make the noise if you just barely hold the pedal down?
zeet is offline
post #3 of 4 (permalink) Old 06-07-2009, 09:23 PM Thread Starter
Hey Zeet,
Thx for the reply, the noise kinda starts if you release the clutch normally or a tad qucik, this happens only 1st & 2nd gear, only if you release the clutch a tad quick.
Would U happen to have any DIY pics for clutch replacments.
Thx
DJR
Daylyn R is offline
post #4 of 4 (permalink) Old 06-07-2009, 11:21 PM
No, sorry. No pictures. Haven't seen them anywhere here, either. It should be pretty straightforward, it's a RWD car so you drop the transmission to do it. I know they had to drop the transmission for a warranty repair on my car, and I had it back in 3 hours, so it can't be that tough.
zeet is offline
C Class W 203 Shifter Knob change jettabenz W203 C-Class 7 01-03-2007 09:16 AM
Missing gear change buttons on steering wheel? skidmark R171 SLK-Class 14 01-24-2006 04:20 PM
steering wheel nosie, removal? cnmcanelly W201 190-Class 3 09-02-2005 07:52 PM
gear knob and steering wheel removal vdubpower W126 S,SE,SEC,SEL,SD,SDL Class 13 12-26-2004 09:10 PM
Gear knob change Neo420 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-26-2003 07:55 PM
