scratched window tint - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-04-2009, 06:54 PM Thread Starter
Date registered: Feb 2008
Vehicle: 2005 C230 Kompressor
Hey all, Thought I would share my solution to my scratched window tint problem. I live in Phoenix so window tint is a must. I had huber optik installed at the dealer only to discover that the rubber window seals left vertical scratches in the tint because the seals are just bare, textured rubber with none of the fuzzy surface treatment usually found on window seals. The dealer was like "tough luck." I had the tint replaced twice under warranty for the scratches. After the second time, I pulled off all of the door panels, removed the seals and used some spray-on adhesive to adhere felt to the seals. It only took a couple hours and now no more scratches.
ruary is offline
post #2 of 14 (permalink) Old 03-04-2009, 10:34 PM
Vehicle: 2004 C230 Kompressor Sport Coupe
This is well known on Benzes, you need to felt the seals inside the door as well as the ones at the top. Surprised the dealer did not know about it.
zeet is offline
post #3 of 14 (permalink) Old 03-05-2009, 11:20 AM
Date registered: Jan 2008
Vehicle: 2005 C230 SS Kompressor
moleskin - Tint Protector's MoleSkin Felt Strips, 10 feet, 20 feet and more!
not sure if i can put links here, if not, sorry go ahead and take down...
Roland...
Rollnnn is offline
post #4 of 14 (permalink) Old 03-06-2009, 01:45 PM
Mrmercedes22's Avatar
Date registered: Mar 2008
Vehicle: 2003 C230k
Yeah, the guys I used to tint my windows have never heard of molskin or using felt material on the window seals. They supposedly have been in the business for 20 years. My drivers side is starting to scratch. I guess I should have found a better company that new what moleskin was.......Live N Learn...
Mrmercedes22 is offline
post #5 of 14 (permalink) Old 05-20-2009, 06:36 PM
Date registered: Oct 2005
Vehicle: SL55, RX400h, RX7
Ya Tint Protector has a kit for the C class.
Check out how bad this C32 tint scratched!
Moleskin Felt Prevents Window Tint Streaks and Scratches
flnsx is offline
post #6 of 14 (permalink) Old 05-20-2009, 08:26 PM
AMGlover4life's Avatar
Date registered: Aug 2008
Vehicle: 2006 c230 sport, 2006 BMW 330
THANK GOD! I thought there was no solution for this problem, dealership told me, too bad, so I have had them redone twice now.
AMGlover4life is offline
post #7 of 14 (permalink) Old 05-20-2009, 08:27 PM
The ones in the 55 and 230 look just as bad as in the picture link provided by flnsx
post #8 of 14 (permalink) Old 03-19-2010, 10:57 AM
I don't understand why so many people working at dealerships are so lame in the head.....
flnsx is offline
post #9 of 14 (permalink) Old 03-19-2010, 06:38 PM
Date registered: Mar 2010
i have the same problem my car is 2007 c230 and tint is all scratched. how do you install this tint protector kit? How do I remove the door panels to install this?
nm2010 is offline
post #10 of 14 (permalink) Old 05-12-2010, 01:03 PM
NM2010,
It's super easy to install. You just have to pop open the door panels. You don't need to remove them. It's like 3 screws or something.
Buy the kit here.
Tint Protector Mercedes Automotive Anti-Scratch Window Tint Kits Made With MoleSkin Felt
It has pictures with the instructions. Worth it hands down over having to re-tint after scratches.
flnsx is offline
    window tint vs. rear side window shades Guest (MBNZ) W203 C-Class 15 11-06-2009 08:47 AM
    window tint Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 14 09-18-2005 06:32 AM
    Window tint 6395j General Mercedes-Benz 1 07-18-2005 07:03 PM
    TO TINT OR NOT TO TINT? Rear Window Dot Matrix Causes Bubbles & Window Seals Scratch... Ken R170 SLK-Class 2 08-21-2002 07:11 AM
    My Tint is completely scratched! Guest (MBNZ) W203 C-Class 4 03-31-2000 01:11 AM
