Help - Will not go past 4000 rpm - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-20-2009, 11:26 PM Thread Starter
Date registered: Jan 2009
There is something weird happening with my 2001 C240. The car won't go past 4000 rpm!
When I rev it at idle, it won't go past 4000 rpm. As if there is a rev limiter.
When I WOT it would hold at 4000 rpm and would not up shift.
When I downshift from higher gear into lower gear but not over revving at low gear, the car seems to be artifically cutting fuel or something....hiting at 3500 rpm only and would not go any higher!
Regular driving and acceleration is fine.....as long as it shifts under 4000 rpm.
bb4srv is offline
post #2 of 4 (permalink) Old 02-21-2009, 10:07 AM
Vehicle: 2004 C230 Kompressor Sport Coupe
Out of gear, it might have a lower rev limiter. I don't have the C240, but some cars do that since there is not much reason to run up to redline while out of gear. But in gear, that really means something is wrong. My gut says MAF, but you should start by checking for codes. You need not just stored but pending. Bring the numbers, not what the person with the tool says they mean.
zeet is offline
post #3 of 4 (permalink) Old 02-23-2009, 12:56 PM
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Many MB's have a rev limiter at idle set at 4,000. As to why it's limiting you while you are driving is more of mistery. Is the check engine light on? Also, check the tranny fluid (you'll need to take it somewhere for this).
http://www.mylavista.com
Buellwinkle is offline
post #4 of 4 (permalink) Old 02-23-2009, 01:31 PM Thread Starter
I have replaced the battery and everything is fine out
Either that, or I have erased the error codes stored.
bb4srv is offline
    ML55 won't rev past 4000 rpm deeksy62 General Mercedes-Benz 2 03-30-2009 10:14 PM
    Motor pulsates at ~4000 RPM!? jacob.osterling W210 E-Class 10 05-05-2008 01:41 PM
    Motor pulsates at ~4000 RPM!? jacob.osterling W210 E50 AMG, E55 AMG 0 05-04-2008 10:49 AM
    4000 rpm miss??? DONNA U R170 SLK-Class 8 03-15-2005 05:54 PM
    MB 230 TE - engine gives up at about 4000 rpm Guest (MBNZ) W124 E,CE,D,TD Class 3 08-15-2002 08:22 AM
