2005 C230K battery change; DIY or pay?? - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 01-20-2012, 11:10 AM
Date registered: Jan 2012
Thanks for the number guys but if I change it out myself will I have to reset any codes? What's the easiest way to do this? Thanks again.
racingluxury is offline
post #12 of 25 (permalink) Old 01-20-2012, 12:02 PM
Date registered: Jun 2009
Vehicle: 96 Saab 900S Conv., 01 BMW 330i, 05 MB C230, 07 Chevy Tahoe LTZ, 07 Silverado Z71
Quoted: 752 Post(s)
Originally Posted by Musikmann View Post
TexFinn is mostly right and IIRC too, if you have paid at least $100 for dealer service in the last 12 months you have coverage.
Yup, forgot about the $100 spend in service.
TexFinn is offline
post #13 of 25 (permalink) Old 01-20-2012, 08:30 PM
rudeney's Avatar
Date registered: Dec 2004
Vehicle: CURRENT: 2011 SL550, 2002 C240 FORMER: 2007 CLK550 Cabriolet, 2001 ML320, 1984 300TD
Quoted: 532 Post(s)
Also, some roadside service centers (usually run by dealers) will actually come out and replace a battery for just the cost of the battery - no labor. It depends on that local service center. It's worth a call. If you DIY, you have to reset ESP (turn the steering wheel lock to lock) and reset the auto-close windows and sunroof (press and hold the buttons in the close position for several seconds after the glass closes).
- RODNEY
http://benzbits.com/rudeney.htm
rudeney is offline
post #14 of 25 (permalink) Old 01-24-2012, 11:53 PM
wynn's Avatar
Can anyone comment on this question?
wynn is offline
post #15 of 25 (permalink) Old 01-25-2012, 01:09 PM
did it!!!!
What I decided to do was connect a jumper cable to the positive and negative spots on the vehicle and the other side of the cable to the new battery. This was VERY tricky cause you don't wanna connect a new battery to the car while the other battery isn't disconnected yet...
So you gotta disconnect the negative from the dead battery and instantly connect the negative to the terminal spot. Then do the same for the positive. Within seconds you wouldn't lose any data. But it's quit hard getting that battery out of the car with cables running around you...plus that damn battery was heavy as hell!!!
Then slowly put in the new battery while making sure your eyes doesn't leave the jumper cable claws... that cannot get disconnected or else you've done everything for nothing. Whew!!! No alarms...no resets...
post #16 of 25 (permalink) Old 01-25-2012, 09:16 PM
rudeney's Avatar
Quoted: 532 Post(s)
I would be very careful doing that sort of thing. MBZ electronics are very "sensitive" and it's very easy to fry a SAM. Resetting the windows, sunroof and ESP takes about two minutes and costs nothing. Replacing a SAM requires several hours at the dealer and is an expensive part.
- RODNEY
rudeney is offline
post #17 of 25 (permalink) Old 01-25-2012, 11:00 PM
right!
You're right...that's why you gotta disconnect and reconnect really fast but don't keep both batteries on at once.
post #18 of 25 (permalink) Old 01-25-2012, 11:04 PM
wynn's Avatar
I believe the question was, how do you reset the windows, sunroof and ESP and anything else that might need to be reset when replacing a battery? Thanks
wynn is offline
post #19 of 25 (permalink) Old 01-25-2012, 11:09 PM
Quoted: 752 Post(s)
Did you read Rodney's post right above your previous post?
Also, window resetting is explained in your Owners Manual. In case you do not have one, you can download it from here: Mercedes-Benz - Home of C, E, S, CLS, CL, SLK, SL, R, GLK, M, GL, G Class.
TexFinn is offline
post #20 of 25 (permalink) Old 01-26-2012, 10:30 AM
wynn's Avatar
Very helpful, thanks to everyone.
wynn is offline
    To Pay or DIY? Which repair manuals are the best? Darkwonders W201 190-Class 9 05-06-2012 12:57 AM
    Oil change for 2005 E320: how much must I pay? seattlehawk W211 E-Class 20 07-25-2008 05:00 PM
    how much to pay for a 2005 C230 Carter W203 C-Class 14 09-07-2004 06:08 PM
    how much to pay for a 2005 C230 Carter General Mercedes-Benz 4 08-23-2004 10:07 PM
    How much should I pay for new 2005 ML500 Special Edition? 2001ml320 W163 M-Class 0 07-24-2004 05:50 PM
