the P0410 code :( - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-17-2009, 10:06 PM Thread Starter
Date registered: Jan 2008
the P0410 code :(
Im assuming i need to get my check valve replaced? anyone know a goodsite? much appreciated! 2002 C230 Kompressor!
ivarzzz is offline
post #2 of 9 (permalink) Old 02-17-2009, 11:08 PM
Date registered: Dec 2004
Vehicle: 1972 280CE
Quoted: 110 Post(s)
air injection system. You should hear the air injection pump run in the morning. It sounds like a hair dryer that cycles on and off. I had that error for months. When I got round to looking at it, I found a broken vacuum line that goes into the valve which was broken. Reconnected it and the light went out a couple of days later.
With best regards
Al
Check out the W114, W115 /8 enthusiast forum http://www.stroke8.org
My 280SL restoration
alabbasi is offline
post #3 of 9 (permalink) Old 02-18-2009, 12:17 AM
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup and 2006 ML350
Quoted: 13 Post(s)
I keep getting a 420 error...it's been suggested my car want to get stoned.
I just clear it...comes back every once in a while under WOT.
2002 C7 Evolution Orion Blue 2.3L C230 Coupe
Auto-Pano-Oyster Leather-Audio 10
AMG Front bar 22mm-17" Wheels- C32 Brakes- H&R 19mm rear sway
ASP Pulley-Supercharger Muffler Deleted- NGK Copper BKR7E
Supersprint Header-Magnaflow Cat- AR20 Resonator- Remus Muffler
MAF Screen Delete- TB Screen delete
TEIN SS Coilovers -
Clear sides- 2005 tails, Blinkers & Grill- Tinted Windows
Bi-Xenons-Clear Fogs- Clear Side/Stealth Bulbs
Renntech Spoiler
C230 Sport Coup is offline
post #4 of 9 (permalink) Old 02-18-2009, 09:49 AM
Date registered: Mar 2008
Vehicle: CLS550 Master Lease, 1990 300zxTT, 2000 camry
Umm the kompressor does not have an air injection pump. This engine uses the kompressor as the injection pump. Usually when I have this code it is caused by the secondary air injection valve. This is located on the passenger side of the engine just above the kompressor. It should have two large tubes and a small vacuum line attached to it. If you have a hand held vacuum pump, hook up to the valve and see if it holds a vacuum. If it does not replaced the valve and vacuum line going to the solenoid on the front of the engine. Good luck
kyle21nluvnit is offline
post #5 of 9 (permalink) Old 02-18-2009, 11:07 AM
Eesjunin's Avatar
Date registered: Apr 2007
Vehicle: 2011 Mercedes E350 4matic Wagon
0410=Injector Relay
...pRoject in pRogreSS...
WTB: AMG skirts
Helpful links:
W203 Seat module fix http://www.benzworld.org/forums/w203-c-class/1403233-diy-how-fix-your-power-seat.html
Mechanic search: http://www.cartalk.com/content/mechx/find.html
HID kits: http://www.tspny.com/shop
Eesjunin is offline
post #6 of 9 (permalink) Old 02-18-2009, 02:01 PM
Date registered: Oct 2008
Ok, here is the run down.
This code (P0410) Secondary air injection, is 99% of the time a bad check valve. The valve is located between the engine block and the firewall. You have to look behind the block to find it. It is connected to a tandem valve, which is just above the check valve and can be seen easily once you remove the top rear engine cover. Look at the vacuum emissions routing sticker under the hood for reference.
Anyway, replace the check valve. And yeah, you can only get it from the dealer.
Part # 002-140-68-60
Evo Pckg.
solobinoy2k is offline
post #7 of 9 (permalink) Old 02-20-2009, 04:41 PM Thread Starter
Hey guys thanks for all your help! i ended up getting a new check vavle, 80 bucks canadian! and replaced it myself..im not gunna lie it was a pain specially if you dont have the right tools, but managed to get a 27mm crow socket and it worked out! seems to be running way better now! just one more question..does it take a couple days for the check engine light be turn off??" thanks again everyone!
ivarzzz is offline
post #8 of 9 (permalink) Old 02-20-2009, 07:23 PM
Vehicle: 2004 C230 Kompressor Sport Coupe
Some codes take 5 successful starts to clear; some take longer. You should pull codes again in case there is another code stored or pending.
zeet is offline
post #9 of 9 (permalink) Old 04-06-2009, 02:57 PM
Date registered: Apr 2009
Vehicle: 2002 C230 Kompressor
I am getting the P0410 code and the car seems to have lost power when this occurs on a 2002 C230 Kompressor. Sometimes the problem goes away. Can anyone narrow down possible causes?
Patrix is offline
    Still Throwing P0410 Code NOLA430 W210 E-Class 11 02-24-2009 11:58 PM
    CEL and code P0410 Shore R170 SLK-Class 19 11-21-2008 01:43 PM
    P0410 Code solobinoy2k W203 C-Class 1 10-08-2008 01:42 AM
    code p0410 rbrandano W220 S-Class 1 08-31-2007 09:49 PM
    Code P0410 and Hesitation agunjal W220 S-Class 0 02-25-2007 09:52 AM
