2004 C240 rear suspension noise - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-14-2008, 11:59 AM Thread Starter
Date registered: Jul 2007
Vehicle: C240 Classic 2003
Post 2004 C240 rear suspension noise
I have a weird noise that i hear from my right rear suspension, it sounds like a metal part hitting a part of the muffer ( or a twanging noise from the spring ). The weird thing is that I only hear it when it rains or when I wash the car. I brought it to the stealership and they couldn't hear it, so I suggested them to wash underneath the car and true enough the sound came out and it sounds when you drive the car diagonally into a bump. I have a schedule with the stealership this Friday, and I'm wondering If anyone had experienced this and can I fix it myself? I would appreciate your help guys!
mikepeang is offline
post #2 of 6 (permalink) Old 10-15-2008, 01:52 PM
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Quoted: 8 Post(s)
Welcome to BW...Off you go to W203 Non-AMG Section...
Cheers,
JOE55
JOE55 is offline
post #3 of 6 (permalink) Old 10-16-2008, 03:21 PM
MBC240's Avatar
Date registered: Mar 2007
I had a bad bushing back there at 60k miles.
I didn't even know it was bad, until a tech told me, and made the noise.
It's probably a bushing.
2003 Mercedes-Benz C240 5AT - 72k miles
1999 Honda Accord EX-L 4AT - 143k miles
MBC240 is offline
post #4 of 6 (permalink) Old 10-23-2008, 12:02 PM Thread Starter
I actually checked all the bushings and sprayed tremendous amount of ceramic lube in all suspension parts. The best thing that happened was the twanging noise disappeared. It still has the squeeking sound but that doesn't bother me as much as the twang. I also checked the springs to see if they are broken and they were fine.
post #5 of 6 (permalink) Old 10-24-2008, 12:36 PM
Date registered: Jan 2008
Im pretty sure this is the rear sway bar bracket bushings.... Ya can replace them OR spend <10 bux and buy some silicon grease and apply it... The spray only lasts so long. Usually the next rain will wash away the spray...
TruTaing is offline
post #6 of 6 (permalink) Old 10-26-2008, 07:04 PM
Date registered: Jan 2007
Vehicle: 2005 C230K Sport Coupe 6-speed! And now a 2011 GLK 350 4Matic in Palladium Silver!
Another thing that may cause a squeak in the rear suspension is where the brake cable enters the back plate. I sprayed the cable with Kleen-Flo Honey Goo, solved the problem.
Whosdis is offline
    Noise from rear suspension Andrzejek General Mercedes-Benz 2 11-14-2011 08:17 AM
    Noise from rear suspension Andrzejek W202 C-Class 7 11-26-2008 10:30 AM
    Suspension noise (rear) - C240 mslc791 W203 C-Class 10 08-17-2007 06:14 AM
    Suspension Noise from rear roadsession W163 M-Class 3 12-30-2002 09:32 PM
    Rear suspension noise Jack R170 SLK-Class 2 06-06-2001 06:57 AM
