Door Lock Stuck - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-20-2008, 06:45 PM Thread Starter
Date registered: Jun 2008
Vehicle: 2002 C320 Sedan
Door Lock Stuck
A couple days ago my driver's door lock knob got stuck in the up position. It won't push down at all, even when I try to push it down. Has anyone ever had this problem before?
If it turns out that my locking mechanism is bad, is it hard to replace?
Randy L is offline
post #2 of 4 (permalink) Old 08-23-2008, 04:45 PM
Black04C230's Avatar
Date registered: Mar 2008
Vehicle: 2004.5 C230 Kompressor Sport Sedan
I have never done one on my Mercedes, but I have done one on my other car. It is a little tricky to do because of the lack of space, but if your a little handy you could probably fix it yourself.
2004.5 C230 Kompressor Sport Sedan.
C55 Lip Spoiler, Roof Spoiler, 3 Fin Grill, Flat Hood Emblem, Clear Corners, Projector Headlights, Eyelids, Projector Foglights, Brabus Door Pins, Smoked Tail Lights, Smoked Third Brake Light, and Window Tints.
Next: C63's & AMG facelift.
Black04C230 is offline
post #3 of 4 (permalink) Old 08-24-2008, 01:00 PM Thread Starter
Update. It tries to engage when locking or unlocking but seems like either a loose electrical connection or is bound on something. When it gets the signal to lock or unlock, it makes a "rapid-fire" kinda sound (the sound of the door lock working but rapidly repeated about 6-7 times) and sometimes the lock engages.
Due to bad weather (TS Fay) and lack of time, I haven't had a chance to open it up. Kinda scared I might damage the door panel and trim.
Randy L is offline
post #4 of 4 (permalink) Old 08-24-2008, 02:55 PM
The door panel is extemely easy to take off. I had to remove mine to put on a new interior door handle. This will give you step by step instructions on how to remove your door panel. InstallUniversity.com: Mercedes Benz C Class W203
Steering lock stuck on? Or ignition lock?.....help! busters the boy! W124 E,CE,D,TD Class 21 05-12-2013 08:09 PM
90 300te key stuck in door lock? donbubba W124 E,CE,D,TD Class 2 07-30-2008 04:08 PM
Door lock stuck!!!WTF!!!Help!!! russoturristo W124 E,CE,D,TD Class 1 11-11-2006 10:54 AM
WARNING:Make sure your hatch door manual lock is set or the hatch door will not lock with the remote AC_ML W163 M-Class 10 12-17-2003 10:16 PM
Stuck door lock driverside Guest (MBNZ) W124 E,CE,D,TD Class 5 02-22-2002 10:19 PM
