Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 08-19-2008, 09:08 PM   #1 (permalink)
Blackvette's Avatar
Date registered: Feb 2008
Vehicle: 2007 Mars Red C230
Help, Wife drove through Puddle and car wont start now...
She drove through a very deep puddle after Tropical Storm Fay... She told me The car stalled and wont start again..
I went to get the car.. I put the key in the ignition and turned it.. Nothing happens.. No click.. the starter makes no attempt to engage...
Also I noticed that the force of the water pulled off the cover in the front side of the driver side wheel well.. There is some electronic (Pump?) stuff exposed there.. Did not look too long as it was pouring rain on us..
Even if the motor ingested water and it was hydrolocked.. The starter would still try to engage...
Any ideas? I have it home now waiting for the storm to pass and dry out...
Oh, its a 2007 C230..
Blackvette is offline   Reply With Quote
Old 08-19-2008, 10:05 PM   #2 (permalink)
rudedude's Avatar
Date registered: Jul 2005
Vehicle: ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
First thing to check is the battery. She may have turned on the flashers as many people do when they are broke down in the road. The battery may be dead. After that remove the air cleaner and make sure everything is dry in there
True success is being the master of your own time.
rudedude is offline   Reply With Quote
Old 08-19-2008, 10:29 PM   #3 (permalink)
RKH
Date registered: Apr 2008
Vehicle: 1998 SL500 Panoramic Roof
Don't turn anything ON until everything is DRY.
While water usually will not damage the electronics (except for corrosion), it WILL short thing out if you power ON and $$$. Better yet, disconnect or remove the battery all together and wait for the hot Florida sun to dry it out.
RKH is offline   Reply With Quote
Old 08-20-2008, 02:18 AM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
like RKH said. wait till everything dried out first before trying again. worse comes worse just call the roadside assistance and tell them you have no idea what happened that the car just won't start. if it's still under warranty the battery should be free. if replacing the battery doesn't work just have them arrange it to get it towed back to the dealership. just make sure you put the wheel well cover back on and leave them no reason to believe it's man made issue from going through the puddle.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 08-20-2008, 10:45 AM   #5 (permalink)
Date registered: Jun 2004
Vehicle: 2008 c350, 2004 c240
Check the front SAM (fuse/relay box) in the engine compartment on the driver's side.
It may have filled with water and needs to be dried out. There is a splash shield over it and then a clipped-on cover.
Don't try to operate the car until you know that box is dried out. Check all your fuses while you're at it.
wblynch is online now   Reply With Quote
Old 08-21-2008, 02:21 PM   #6 (permalink)
Blackvette's Avatar
Thanks guys, Actually I caled the insuance company..I am covered.. It was flatbedded back to the dealer last night.. Hope to hear shortly what the problem is...
Drove my CLK under water, car wont start anymore abaja W208 CLK Class 34 08-07-2007 04:20 PM
Please Help, Car Wont Start madmanmerc General Mercedes-Benz 9 03-30-2007 08:11 PM
HELP! Car wont start :( 83300cdtCal W123 E,CE,D,CD,TD,TE Class 15 01-04-2007 08:00 PM
Drove my car in a puddle Biiqdan530 W203 C-Class 5 04-24-2006 04:45 PM
Why Wont My Car Start???!! AMSOIL300CDT W123 E,CE,D,CD,TD,TE Class 15 09-14-2005 07:28 PM
