P0237 Turbo/Super Charger Boost Sensor 'A' Circuit Low - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 07-30-2008, 09:38 PM Thread Starter
Date registered: Jul 2003
Exclamation P0237 Turbo/Super Charger Boost Sensor 'A' Circuit Low
2003 C230K C-Coupe 6 speed w/ ~69k miles
supercharger is being bypassed and that's the code that came up with the CEL.
any ideas?
and to rule out some guesses:
- it shouldn't be the pcv valve issue as we had that done at the dealer several months ago.
- it also shouldn't be the oil feeding down the wire harness via the camshaft sensor as i've already added the new connectors at the sensors a while ago.
thanks in advance.
reno96teg is offline
post #2 of 14 (permalink) Old 07-31-2008, 09:32 AM Thread Starter
should i just start randomly replacing things?
post #3 of 14 (permalink) Old 07-31-2008, 10:16 AM
Date registered: Jul 2008
Vehicle: C200 Kompressor M111 2.0L Avantgarde Year 2002
You can use search engine to find "P0237" issues. There are lots of info.
I got one (not P0237) very useful article regarding engine problems.
DIY Booklet - Do It Yourself with the Autotap OBDII Scantool
W203 C200K M111 2002
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #4 of 14 (permalink) Old 07-31-2008, 10:22 AM
P0237 (M) Map Sensor Voltage Too Low MAP sensor voltage input below the minimum acceptable voltage.
MAP is the same of MAF..? I am not sure...
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #5 of 14 (permalink) Old 07-31-2008, 11:55 AM
Found it..! not the same.
MAP = Manifold Absolute Pressure
MAF = Mass Air Flow
Engine M111
MAP is the part No.80
Still got check light on, I will check mine too...
Denso Iridium IK20
Ground wires SARD
DangTH is offline
post #6 of 14 (permalink) Old 07-31-2008, 01:48 PM Thread Starter
oh great, this definitely helps, thank you.
i don't suppose you have the location on the M271?
post #7 of 14 (permalink) Old 07-31-2008, 04:41 PM
Vehicle: 2005 C230 K
Wouldn't this be a possible vaccum leak?
MelloC230 is offline
post #8 of 14 (permalink) Old 08-01-2008, 07:08 AM Thread Starter
could it be? i don't know. i've never had to troubleshoot vacuum leaks before.
post #9 of 14 (permalink) Old 08-02-2008, 01:33 PM Thread Starter
ok, i think i may have figured it out. the air pipe running to the throttle body was a bit loose. as such i think it was leaking. i pushed it back in and went for a drive and things felt normal. i'm going to order a new gasket and clamp, and after a week report back.
post #10 of 14 (permalink) Old 08-04-2008, 01:52 PM
Date registered: Dec 2006
Vehicle: 04/C230K SportSedan Blk/Blk, 08/C300 SportSedan MarsRed/PremiumII,18"AMG
You should have checked this TSB 2008020002 recall for 2003-2005 C-Class first.
pthai2 is offline
    Which O2 sensor? P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) ClkE C208/A208 CLK-Class 3 05-16-2008 05:44 PM
    Super Charger...? bwmc W203 C32 AMG, C55 AMG 0 04-21-2008 08:12 AM
    i need a super charger suki85 W202 C-Class 0 07-27-2006 05:42 PM
    not only super charger.super sound to JBL supercharger6.9 W116 S, SE, SEL, SD Class 6 12-02-2005 06:23 PM
    If MAF sensor is not working will it cause the super charger not to come on? Jeffrimerman R170 SLK-Class 5 07-19-2003 01:16 PM
