» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-19-2008, 10:22 AM   #1 (permalink)
Date registered: Jun 2008
Vehicle: 2002 C320 Sedan
Oil Dipstick Location on C320?
This is embarrassing! I can't find the oil dipstick on my '02 C320!! I see the oil filter. Where's the dipstick located?
Also, the plastic engine cover...is there a special way to remove it?
Randy L is offline   Reply With Quote
Old 07-19-2008, 10:41 AM   #2 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
Dipstick - possibly there isn't one. Depends on year/model. On my 04 CLK they had been discontinued and all I have there is a dummy red plastic plug in the dipstick tube. All oil level readings are available at the cluster.
Plastic covers are held in place by about 4 clips. Grab the cover with a hand on each side, and give it a sharp yank upwards. It won't break, but mind your knuckles! It is important to get it positioned correctly when you replace it.
keyhole is offline   Reply With Quote
Old 07-19-2008, 01:52 PM   #3 (permalink)
^^ thanks for the tip on the engine cover. After a google search I found that my car has its oil tube at the rear of the engine, where domestic cars' tranny dipstick normally sits. Mine has a black cap on it.
I was shocked to see that the engine requires 8 quarts of oil!
Old 07-19-2008, 02:52 PM   #4 (permalink)
jrsmith_68's Avatar
Date registered: Mar 2007
Vehicle: 2007 C350
More oil = longer change interval.
jrsmith_68 is offline   Reply With Quote
Old 07-20-2008, 09:12 PM   #5 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
Randy, the tube at the rear should be the trans tube. The engine oil tube is near the front right hand side near the intake tube.
Whosdis is offline   Reply With Quote
Old 07-26-2008, 07:37 PM   #6 (permalink)
Never saw one there. Need to take another look.
2001 C320 Oil suck Location juejaimon W203 C-Class 1 06-10-2008 04:52 AM
Oil dipstick. gmund W220 S-Class 9 04-06-2008 08:36 PM
location of oil filter and dipstick on 2005 e320 cdi rdalbright W211 E-Class 8 03-31-2008 07:13 AM
Oil dipstick FLYNAVY W126 S,SE,SEC,SEL,SD,SDL Class 1 02-10-2008 01:38 PM
All C240's without an oil dipstick and other oil related ???'s Dr. T W203 C-Class 5 12-22-2003 08:51 PM
