Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-17-2008, 06:12 AM   #1 (permalink)
Eesjunin's Avatar
Date registered: Apr 2007
Vehicle: 2002 Mercedes C320
Lightbulb Wheel Spacers
Thinking of installing 20 mm wheel spacers for a wider look. Any downfalls to that? Can you post the pics of your car with wheel spacers just to see the variety and how it looks?
Any specific brand anyone would recommend? I got stock rims, which i dont plan replacing, and lowered with Teins.
Custom painted front lense covers and grill; Tein Lowering springs; Custom Flowmaster dual exhaust; K&N filters; de-badged; Euro style rear window spoiler; AMG trunk lip
Riegers body kit;
Eesjunin is offline   Reply With Quote
Old 07-17-2008, 07:13 AM   #2 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
5mm spacers
I have them just on the front so my rims/tires clear the suspension. You'd def need longer bolts and I heard that the more 'spaced' your car is the worse off your handling is. Don't know how true that is. My car rides better due to the larger rims.
Tri-Star is offline   Reply With Quote
Old 07-17-2008, 07:33 AM   #3 (permalink)
Eesjunin's Avatar
hmm.i deff read about the longer bolts. But putting the wheels wider doesnt that make it more stable?
Old 07-17-2008, 12:26 PM   #4 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
I think 20mm will stick out too far, past the body, and that would look bad. I would recommend 10-15mm at most. Widening the stance of the vehicle will increase handling a little, but if you go out to far it will degrade the handling. I've been looking into spacers for my car, but I wanted to use 5mm, and I'm only finding 10mm lowest... 10mm might work out pefect though, but it seems a little too much.
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 07-17-2008, 02:38 PM   #5 (permalink)
Date registered: Feb 2008
I have 10mm front and back and think it gives it a great look. I have heard that you are not supposed to go more than 5mm in the font or it will throw off the suspension but im all good.
osuguy81 is offline   Reply With Quote
Old 07-17-2008, 07:12 PM   #6 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
on stock wheels 15mm will be plenty. H&R hub centric spacers are the way to go. You do need longer bolts if you decide to get spacers. I personally would just look for a set of 17" take offs from other sports sedan owner if you don't want to spent a lot of $$ on wheels. They usually go for around $500-600 for a nice set of 17" sport wheels.
wider = more stable, but also = less turn in response. however with stock 16's and basically touring tires you won't feel any difference.
for the H&R spacers they're about $100-120 a set. you'll need two sets if you want to space out both fronts and rears. IMO it's better to save the $$ and do as I suggested in the first paragraph.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 07-18-2008, 06:13 AM   #7 (permalink)
Eesjunin's Avatar
Thanks guys... Thats probably what i will do, i will try to search around for the 17"
It does make sense!
Thanks again!
Wheel Spacers Bazzle R170 SLK Class 15 06-02-2008 12:59 AM
wheel spacers? tim757 W203 C-Class 1 07-14-2004 04:45 PM
Wheel spacers... 300E W124 E,CE,D,TD Class 7 07-21-2003 09:14 AM
wheel spacers balida W202 C-Class 0 08-15-2002 07:14 AM
Wheel spacers Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 07-19-2002 06:17 PM
