Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-15-2008, 10:01 AM   #1 (permalink)
hcr280's Avatar
Date registered: Jan 2007
Vehicle: * 2003 C240 w/61k * 1994 C280 w/226k! Totaled 06/16/08 *
Send a message via Yahoo to hcr280
2003 C240 Door Lock Problem
When using key fob to lock car, the driver side door lock knob jumps up and down. Sometimes it locks and sometimes it dosen't. After a few tries it may work, if not I use the flat key. Suggestions?
* 2003 C240 Wht/Tan
* 1994 C280 w/226k! Blk/Blk Totaled 06/16/08
hcr280 is offline   Reply With Quote
Old 07-15-2008, 11:18 AM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
It could be that one of the door lock plungers is jambed or disconnected from it's rod. I had this happen on my C230, the plunger was disconnected so it jambed against the side of the door and wouldn't unlock in my case.
Old 07-15-2008, 04:34 PM   #3 (permalink)
Date registered: Jan 2008
Vehicle: 2002 C230 Kompressor Coupe
Sounds like the Door Lock Mechanism. I just replaced mine this past weekend. Purchased from allmercedes.com. There are a couple threads here, one was Door Lock Solenoid "Bounce" that I found invaluable if you do it yourself.
rmcfarlin is offline   Reply With Quote
Old 07-15-2008, 06:25 PM   #4 (permalink)
MBC240's Avatar
Date registered: Mar 2007
Mine went out, I had a warranty but it would have cost me $450 to replace. And that was at CarMax, not at Mercedes.
Expect to pay $500 at the dealer. The problem was the door lock motor/actuator.
2003 Mercedes-Benz C240 5AT - 65.4k miles
1999 Honda Accord EX-L 4AT - 128.2k miles
1996 Honda Accord LX 4AT - 120.6k miles
MBC240 is offline   Reply With Quote
Old 07-16-2008, 07:34 AM   #5 (permalink)
Date registered: Jun 2008
Vehicle: 2004 Mercedes C230 Kompressor Sedan
I had both driver and front passenger door locks do this. Both were repaired/replaced under warranty fortunately.
mystery905 is offline   Reply With Quote
Old 10-02-2008, 01:13 PM   #6 (permalink)
victorcaloca's Avatar
Date registered: Jul 2008
My driver's side door lock is doing exactly the same.
Is there a do it yourself guide to this motor/actuator or solenoid replacement ? I would hate to break any plastic clips when bringing the door panel off.
thanks
______________
2004 Mercedes-Benz C230 Kompressor 65k miles
victorcaloca is offline   Reply With Quote
2001 C240 DOOR LOCK PLEASE HELP RRC_95 W203 C-Class 2 02-14-2008 05:57 AM
C240 door lock problem props W203 C-Class 2 04-24-2007 04:31 AM
Door Lock Problem 79Mercy W123 E,CE,D,CD,TD,TE Class 5 03-07-2007 05:01 AM
Door lock problem (I think) asianml W163 M-Class 20 03-20-2006 02:32 PM
door lock problem hawee W163 M-Class 5 07-04-2005 04:33 PM
