I have been hunting the vast interweb to try and explain what is the deal with my c230k. It started 2 months ago when I got a check engine light driving home from work. I took it to the dealership to get it scanned and I was told that the downflow 02 sensor needed to be replaced. At first I was kinda of surprised by this because my car only has 44,000 miles on it. Well after the part was replaced, I was CEL free for about a month. Again when I was driving home from work the CEL came back on. I used a obd 2 scanner to check for codes. This time it was a p0130. I replaced the upflow 02 sensor and now have 3 codes dropping. p0130, p0137, and p0170. From reading other examples of 02 sensor codes, should I assumed that my MAF is the next logical step in trying to solve this problem. I don't want to start replacing random components now. Any suggestions would be greatly appreciated.
Beer shall rain from the heavens...
It's could be the MAF. First reset the codes, unplug it and drive around for a while. If it runs better then it was the MAF. You will get a MAF code like a P0100, that's OK, it's because it's disconnected but if you get the old codes like P0170 and such then it wasn't the MAF.
Thanks for the reply. I will give it a try. One thing I did not mention is that the car does not seem to drive differently. I don't notice much of a power loss if any. However there have been situations where I am driving and the car stutters. This happened at a stop and during driving. The stuttering though hardly happens and occurs randomly. I have yet to have a stuttering problem with the newly installed up flow 02 sensor.
What I am trying to figure out is that since the p0170 is a pending code and not active now then it is not the code I should worry about? Since this code is only pending then this leads me to believe that I am not near any tolerance (ie running too rich or lean). Therefore why would I be dropping 02 sensor codes as active codes? This is my first merc so does it take a few driving cycles for the codes to clear themselves? Do I need to go to the dealer to basically have them hook up a STAR, clear the codes, and tell the ECU to relearn with the new 02 sensors?
You can read and clear codes using an OBD2 scanner. They range in price from about $50 on up depending on features and the simplest ones can read/reset codes, the fancy ones log sensor output and give you code definitions.
