Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-13-2008, 10:21 AM   #1 (permalink)
Date registered: Jul 2008
Vehicle: C 230 Kompressor '04
Wiper "misses" the rain
The passenger side wiper misses a section the size of my hand near the center of the windshield. We replaced the blades to correct the problem, but it still happens. The other areas, as well as the driver side are perfect, no chatter etc. Any suggestions?
Her C230 Kompressor is offline   Reply With Quote
Old 07-13-2008, 12:14 PM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Welcome to the forum.
It's tough to get replacement blades to sit right sometimes. Just get a whole new wiper arm and it will be fine or move here to So Cal, we don't get rain here.
Old 07-15-2008, 10:10 AM   #3 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
Try pushing the blade down against the window.
Tri-Star is offline   Reply With Quote
Old 07-15-2008, 12:45 PM   #4 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
If you only replaced the rubber wiper than you may have a Wiper BLADE problem.
You know those things flex and have springs and hinges etc.
Recommend you replace the entire Wiper Blade.
That "should" take care of your problems.
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 07-15-2008, 02:37 PM   #5 (permalink)
Date registered: Sep 2007
Vehicle: C 200 CDi estate 2003
Not a rubber problem. If you lift the wiper support, you'll see a spring. Pass something to tighten the spring (ie an electric plastic clamp...), tighten it with the wiper LOWERED. That is a spring problem.
jobela is offline   Reply With Quote
Old 07-15-2008, 02:38 PM   #6 (permalink)
Or just replace the spring...
Old 11-11-2008, 12:55 PM   #7 (permalink)
Date registered: Nov 2008
Vehicle: 2004 C230 Kompressor
I have the same problem. The dealer told me that it is a know issue with the arm. They adjusted it and it was better but I still have the problem.
alamusga is offline   Reply With Quote
Old 11-11-2008, 05:59 PM   #8 (permalink)
jrsmith_68's Avatar
Date registered: Mar 2007
Vehicle: 2007 C350
I had the same problem too. My wiper was not fully engaged in the clip on the arm. Reinstalled and it went away.
jrsmith_68 is offline   Reply With Quote
Clinton Advisor: Indianans "Shit", "Worthless White N*rs", Indiana Primary Next Week. Jakarta Expat Off-Topic 4 05-02-2008 03:07 PM
"Extra" wire at my windshield wiper tank andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2008 11:02 AM
"ANCO" wiper blade seems to make tiny scratches on my windshield? ProV1x W210 E-Class 1 08-17-2007 12:07 PM
"Yakuza" Sato's AMG Mercedes from "Black Rain" (starring Michael Douglas&Andy Garcia) JJB236 W124 E,CE,D,TD Class 20 08-06-2007 09:12 AM
