Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-13-2008, 12:25 AM   #1 (permalink)
Date registered: Jun 2008
Post weird wearing on rear brake pads?
On a 2003 c240 4matic, I got the brake pad light the other day so I decided to change out the rear pads first then the front ones. When I pulled the rear pads off, the were not completely on the rotor.
Basically, the front edge of the pad extended to where it should, but the back edge of the pad stuck off the edge of the rotor a quarter to half an inch or so, making it to where the pads would actually contact them selfs when worn down half the thickness of the rotor.
Is this extension off the back of the rotor normal on these cars? Did someone install the wrong rotor during the last brake job?
rshelton is offline   Reply With Quote
Rear Brake Pads Michilein W202 C-Class 4 07-18-2007 03:54 PM
w123 rear brake pads=VW beetle front pads? eurobluebenz W123 E,CE,D,CD,TD,TE Class 9 05-09-2006 07:28 PM
Official Now: My original rear OEM brake pads lasted 74, 500 miles. I bought new OEM pads, a brake AC_ML W163 M-Class 2 02-07-2004 05:25 PM
Is it okay to change front brake pads and then change rear pads about a month later? jay (new jersey) R170 SLK Class 3 06-23-2003 01:59 PM
Thanks for pics JimB, changed brake pads this weekend no problems, frt pads had more wear than rear Dave L. W163 M-Class 13 02-25-2002 10:48 PM
