» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-12-2008, 02:36 PM   #1 (permalink)
maxximus's Avatar
Date registered: Jul 2008
Vehicle: 05 c230 sport
performance
I currently own a 05 c230 sport and am looking for better off the line performance. Has anyone purchased and installed an affordable performance chip that they can recommend. I am not looking for racetrack speeds but I would like to get a little more out of the car. Any other suggestions would be appreciated as well.
Thanks in advance.
maxximus is offline   Reply With Quote
Old 07-12-2008, 02:54 PM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Doesn't say if you have a slush box or manual but since most MB's are slush boxes, research the SprintBooster. Won't make anymore HP but it will give you a better seat of the pants experience. If you want to add HP, there are some chip companies but keep in mind that for $500+ you will not likely feel any difference, just a few ponies. Also stay away from cheap aftermarket wheels that are heavy and slow you down. A set of 19" wheels that cost under a few thousand will likely rob you of a full second in 0-60.
Buellwinkle is online now   Reply With Quote
Old 07-12-2008, 05:30 PM   #3 (permalink)
Black04C230's Avatar
Date registered: Mar 2008
Vehicle: 2004 C230 Kompressor
K&N airfilter and exhaust would probably be the cheapest options.
04' C230 Kompressor
Black04C230 is offline   Reply With Quote
Old 07-12-2008, 10:42 PM   #4 (permalink)
Date registered: Jun 2008
Vehicle: 2005 MB C230 Kompressor, 1997 Ford F-350 PSD
what type of gains are generally seen from the exhaust and k&n? does k&n have a kit specifically for these cars? ive done a bit of research on exhaust upgrades and have generally turned up very little as to what brands do a full engine back system. any suggestions?
2005 C230 Kompressor Sport Sedan
- Stock........for now!
1997 Ford F-350 Powerstroke
- Modified to the hilt!
- for sale!
FFemt5287 is offline   Reply With Quote
Old 07-13-2008, 12:41 AM   #5 (permalink)
maxximus's Avatar
The SprintBooster sounds like a good place to start. Does anyone have one they are looking to sell?
Thanks again for your time.
Old 07-13-2008, 03:47 AM   #6 (permalink)
check the for sale section. i saw two on there, i think between 200 and 250.
Thanks Once again..and KO Performance?? themachinist R170 SLK Class 7 05-06-2008 10:45 AM
Performance for the '87 300SDL? Any suggestions for the W126.125 performance parts or lewayhun W126 S,SE,SEC,SEL,SD,SDL Class 9 08-21-2007 08:59 AM
A/C performance p100 W123 E,CE,D,CD,TD,TE Class 8 07-27-2007 07:55 PM
Help 4.5, 6.3, 6.9 Performance solicit Vintage Mercedes-Benz 3 05-02-2004 08:45 PM
performance renntech W201 190E, D-Class 2 02-03-2003 05:33 PM
