Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-10-2008, 09:24 AM   #1 (permalink)
Date registered: May 2008
2005 C230K Erratic Gas Mileage...
I was wondering if any one had suggestions for my issue:
I have a 2005 C230K Sedan and I usually get very good gas mileage out of it (25 - 27 mixed & 31-32 straight highway). Lately I have been sporadically getting 19 - 22mpg (~21.4 over two tanks of gas). I haven't changed anything (ie: driving style, route to work, gas grade, etc) and the MB dealership near me says there is nothing wrong because they aren't getting any computer codes.
Do you guys have any suggestions? BTW this is the same dealer that has the car for the 4th time to get rid of the same squeaky seat noise.
Thanks in advance...
-Matt
renisis is offline   Reply With Quote
Old 07-10-2008, 09:32 AM   #2 (permalink)
Another thing to note is that I will still see good gas mile occasionally.
It really sounds like a computer / sensor problem to me but MB keeps insisting that they can't do anything unless there is a code.
Old 07-10-2008, 09:34 AM   #3 (permalink)
Date registered: Jun 2008
Vehicle: 2005 MB C230 Kompressor, 1997 Ford F-350 PSD
i have the same car and consistantly see over 30mpg (as high as 39) per the computer and hand calculated at every fillup with 93 octane fuel. thats mostly around town driving (rural, 45-55mph)
have you bought heavier shoes?
2005 C230 Kompressor Sport Sedan
- Stock........for now!
1997 Ford F-350 Powerstroke
- Modified to the hilt!
- for sale!
FFemt5287 is offline   Reply With Quote
Old 07-10-2008, 09:54 AM   #4 (permalink)
Nope... Everything is stock and the tires have been the same since I got the car (some flavor of Dunlop)...
I was impressed at the mpg when I first got the car, but now I am wondering what the hell happened.
-Matt
Old 07-10-2008, 03:57 PM   #5 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
How many miles does the vehicle have? You might want to clean the MAF sensor. It will get dirty over a relatively short period of time, and that can cause a rich burn. Might be the cause of your bad gas mileage. If it's just dirty there will be no CEL, or pending codes, so just because the dealership says there are no codes definitely doesn't mean everything is alright... If that doesn't seem to help try a different gas station to fill up at. It's possible they filled the resevior with regular unleaded instead of premium, or just got a shipment of bad gas. Also, check your tire pressure if you have not done that already. When is the last time you had your tires balanced and/or rotated?
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 07-10-2008, 04:16 PM   #6 (permalink)
Date registered: Jul 2008
Vehicle: 2005 C230 K
I would have to agree with 2002C230 on the tire pressure and gas station comments. Due to weather change tire pressure will be affected which will cause a variation in overall mileage. You cannot rule out the gas station theory. Just because it's listed as XX octane on the pump does not mean that is what's being pumped into your tank. Gas is never consistant from one gas station to the next. Try to stick with the same petrol station if possible and try to stay away from the Pot Lot gas station. Sure their prices are low but there is a reason for it
MelloC230 is offline   Reply With Quote
Old 07-10-2008, 05:57 PM   #7 (permalink)
I can't say the gas station theory isn't a problem but I already did check the tire pressure and since the tires are only a few months old I wasn't even thinking about rotation/balance.
The car has 35000 miles on it (there were 32500 when I bought it).
The strange thing about the problem is that it doesn't happen predictably (ie: due to gas). I went to my family's house for 4th of July and going there the computer read 20mpg and on the way back (I was taking it extra easy on the car both ways) I got 28 mpg.
So I asked the dealership to take a look at the MAF sensor this afternoon. Hopefully tomorrow they'll give me a car back that had a dirty sensor but we'll see.
BTW thanks for the help. I appreciate it.
I did have another quick question: My wipers have the rain sensor but will go off randomly while I'm driving when it's not raining. The dealership told me they are suppose to be off unless its raining but I thought that was BS. I know how the sensor works (the curse of being an engineer) but I didn't want to keep pushing the issue if I am truly mistaken. Any thoughts?
Thanks again,
Matt
Old 07-11-2008, 09:11 AM   #8 (permalink)
Keep us posted on the MAF issue as my C230 has about the same mileage as yours. I do notice though mileage can also be based on traffic conditions. On the weekends I get better gas mileage due to lack of traffic but during the weekdays when I commute to work I hit periodic pockets of stop and go traffic which does affect my overall mileage on the highway.
Old 07-11-2008, 10:16 AM   #9 (permalink)
mediatwin2's Avatar
Date registered: Aug 2007
Vehicle: 1999 ML320 / 2005 C230
I picked up my wife yesterday from work as usual. the lights had changed timing due to construction. My computer dropped from 25MPG to 16MPG, just be sitting at 6 consecutive red lights in 85 degree weather....even the littlest changes can affect MPG. If the windows are open, you can watch the drag pull the MPG numbers down, Heavy shoes screw up the pedal feel and suddenly you are changing your habit without noticing.
Oh and the Rain sensor thing......my SA told me that leaving it on when dry is no problem, you just have to put up with the schizophrenic activation, seems one of those "personality" things. I have an expansion seam on a bridge I drive over, that is guaranteed to send them wiping.....
mediatwin2 is offline   Reply With Quote
Old 07-11-2008, 02:18 PM   #10 (permalink)
RodrigoMex's Avatar
Date registered: Dec 2006
I would suggest you check the parasitic weight you carry on your trunk (get rid of it), and inflate your tires with a couple extra psi's on your tires as indicated in the manual (inflate always with pure nitrogen). That way you'll get just a little bit harsher ride, but better dynamics, less pot hole tire damage risk and increased gas mileage.
The above is independant and always a nice extra besides ensuring clean gas and air filters, properly cleaned MAF, and proper working spark plugs, but if you are getting erratic fuel milages I don't think this basics apply to your case.
COMISIÓN DE PILOTOS ASOCIADOS A.C.
México's 2005 & 2006 Interclub Rally Champions
'98 Euro SPEC BMW M3 E36, S50B32 321 bhp
'04 Audi A4 Quattro 1.8t
05' MB C230K SS (Koni FSD, Eibach, del Río Powered)
RodrigoMex is offline   Reply With Quote
2002 C230K SportCoupe - Gas mileage suuuuuuuucks BLK W203 C-Class 9 03-20-2007 07:31 AM
2005 C230 gas mileage soman11 W203 C-Class 11 02-14-2007 01:10 AM
Gas pills that give you better gas mileage!?! firstmb Off-Topic 0 04-07-2006 09:28 PM
Mileage - 2005 C230k tslocum W203 C-Class 18 06-06-2005 12:10 AM
2005 C230K sedan gas mileage? itechand W203 C-Class 3 08-26-2004 08:33 PM
