Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-10-2008, 08:32 AM   #1 (permalink)
Date registered: Jul 2008
Help please....possible transmission problem?
hi everyone, i have a 03 c230kompressor with a big problem. yesterday I broke down on the highway...I started to hear this high pitched noise that went with rpm''s...after a few minutes the car started to decelerate and felt like it was out of gear. I pulled over and sure enough when trying to accelrate nothing happend just rpm''s going up no gear.
Car was towed to MB dealership in the area. 6 hours later and $750 later car was supposably fixed.....they stated that they have replaced the transmission contact plate.
so everything great car works and drives. I get back on the road today and I start hearing the same noise.....sure enough a few minutes later same thing.....car won''t shit into higher gears and loses speed. I pull over "park" turn the car off and back on and shift into "d" but no gear... same for the reverse. I tried a few more times....sometimes it would shift into 1st? gear and accelrate very slowly and the loosing gear again.
anybody know what this is?
thanks for your help in advance...
tangtang is offline   Reply With Quote
Old 07-10-2008, 07:22 PM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
i would take it back and demand they look at it again. and it happened that fast, they probably misdiagnosed the issue.
Streetglower is offline   Reply With Quote
Old 07-11-2008, 07:41 PM   #3 (permalink)
so....today the delaer is telling me I need a new trnasmission because the "fluid is milky" and it had an internal failure.
Sounds to me like they have no freaking clue whats wrong with it.
Old 07-11-2008, 08:48 PM   #4 (permalink)
Black04C230's Avatar
Date registered: Mar 2008
Vehicle: 2004.5 C230 Kompressor
I would demand they give me a refund for that contact plate they misdiagnosed first off. I would also take the car to another dealer and to some independents to make sure that it indeed needs a new transmission. DO NOT always trust the dealer. They tried to screw me on my car with transmission problems also before it was about to go out of warranty. Mine had the acceleration with rpms and no gear also. It also slammed into gear and did not shift sometimes. They said mine was fine and just needed a new sensor. After bitching for a week I ended up with a new transmission.
2004.5 C230 Kompressor.
C55 Lip Spoiler, Roof Spoiler, 3 Fin Grill, Flat Emblem, Clear Corners, Smoked Tail Lights, Smoked Third Brake Light, and Window Tints.
Black04C230 is offline   Reply With Quote
Is this a serious problem with transmission? Mr X W210 E-Class 13 11-13-2006 09:05 PM
Problem with transmission klvana W124 E,CE,D,TD Class 1 05-04-2006 05:19 PM
Transmission problem? Avezbakiyev W210 E-Class 22 09-14-2005 02:17 PM
Transmission Problem ellgee116 R129 SL Class 3 04-17-2004 10:34 AM
Brake padal vibration problem + transmission problem Majid Mansoori W210 E-Class 11 09-22-2003 08:33 PM
