» Site Navigation » Other Sites
» Network Links
07-05-2008, 10:00 AM
#1 (permalink )
Date registered: Jun 2007
C230 Kompressor idle surging
Has anyone run into this--- I have an 04 C230 kompressor 80K miles- I had zero problems with this car. At Idle ( only when hot) the idle surges up and down quickly about 200 rpms (hunting), it sounds like a miss,rough idle and intake backfiring. It runs fine before getting to operating temp. If you lift it off idle (1200rpm, no problems). Highway driving - runs great.
possible EGR or tps sensor? I ruled out plugs or coil pack.
Any advice would be appreciated.
07-06-2008, 12:34 AM
#2 (permalink )
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
did you had the recall done? if not...check for oil leak from cam.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
07-06-2008, 07:57 AM
#3 (permalink )
Thank you for the reply. I am second owner, do you have the recall info or a link?
Thanks.
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post surging + overrevving idle Tephra W124 E,CE,D,TD Class 2 01-23-2008 08:16 PM Surging Idle bigdon W126 S,SE,SEC,SEL,SD,SDL Class 2 07-24-2007 02:06 PM surging idle floridabenzboi W123 E,CE,D,CD,TD,TE Class 25 03-24-2005 11:06 PM Idle Surging John Hermann W126 S,SE,SEC,SEL,SD,SDL Class 1 11-21-2002 07:55 PM 2.6 and 3.0 idle surging Guest (MBNZ) W124 E,CE,D,TD Class 2 02-17-2002 06:38 AM
