Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 07-04-2008, 03:09 AM   #1 (permalink)
CHLUTES's Avatar
Date registered: Oct 2007
Vehicle: 07' C Class
07' C230 Outside Temperature Indicator at 185 Degrees
I mean it has been hot in San Diego, and our garage has no ventilation, but 185 degrees outside.
This happened after I removed the air-conditioning cabin filter on the passenger side. Once I replaced outside temp is now showing 185??
Please help
Also, Check Engine Light is on too. However, the oil temp is normal.
I have 20k miles on it, please don't tell me car is starting to act up?
CHLUTES is offline   Reply With Quote
Old 07-04-2008, 07:44 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
when it says 185 that means there is an open circuit somewhere in the wiring. or the sensor is unplugged.
Streetglower is offline   Reply With Quote
Old 07-04-2008, 11:42 AM   #3 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Sensor is up front in the bumper by the fog light black mesh. It's a hole, maybe 1/2" diameter and there should be a cone shaped sensor pushed into it. If it's missing, maybe a rock hit it on the 5 freeway, then it could be loose inside the belly pan. You can access the sensor by jacking up the car and removing the front part of the plastic inner fender or removing the belly pan (easier) an reach in from behind. Either way, nothing to do with changing any filter. To be safe, stay off the 5 forever, it's way to crowded by you anyway. Is the fair over yet? Are they racing there yet?
Old 07-06-2008, 10:08 PM   #4 (permalink)
Date registered: Feb 2008
Have the same problem. I tend to think that there is a circut problem. My intrument cluster is drawing 185 milli amps as well. I removed my instrument cluster and had it checked out. It appears to be fine. I had replaced my temp sensor before i removed the cluster (you can reach it from under the hood if you have long arms and know where to look) and no change, temp still reading 185 degrees. I am waiting to get my instrument cluster back as i shipped it to Michagan. Have read somewhere that if you unplug the instrument cluster and wait for a minute and plug it in it resets? That's what i am hoping for now.
menno01 is offline   Reply With Quote
Old 07-07-2008, 03:17 AM   #5 (permalink)
like i mentioned above, the usual cause is a wiring issue. when the temp reads 185 there is an open circuit somewhere. the cluster will not cause this. all the cluster does is displays the temp. this is very common on the c classes.
Old 07-07-2008, 07:22 PM   #6 (permalink)
what kind of wiring issues could their be? is their a relay or?
Resetting Service Indicator and oil change 2000 C230 kompressor sport sedan adamr W202 C-Class 2 05-25-2008 09:49 AM
outside temperature sensor reading 85 degrees constantly menno01 W203 C-Class 3 04-26-2008 07:20 AM
Thermostat: 70 degrees vs. 80 degrees C Frans G-Class 7 10-09-2006 03:12 PM
185 degrees? tozfeekum W203 C-Class 1 04-15-2006 08:46 PM
Outside Temperature Indicator TheKompressor W211 E-Class 0 09-23-2005 09:41 AM
