Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-29-2008, 05:58 AM   #1 (permalink)
Date registered: Dec 2007
coolant warning lamp staying on
hello have a probelm hope someone can help?i have c320 2002 and coollant warning light coming on all time.it is also has the engine fan running all the time.i have changed the coolant level sensor but no difference.it is running at correct temp.does overheat etc.can any tell me where the fan relay is .thanks
tbca21 is offline   Reply With Quote
Old 07-01-2008, 11:01 PM   #2 (permalink)
nelsong5's Avatar
Date registered: Feb 2008
Vehicle: 2005 C240 Luxury Sedan
Probly the sensor is messed up, i remember that when my C240 had the warning for the coolant, i just added more of the coolant and it went away. Also try to check everyday after the engine is on for a while if the temp of the car is the same, if it gets higher then you might have a problem and you can dicard that the sensor is the trouble maker.
nelsong - MB lover.
nelsong5 is offline   Reply With Quote
Old 07-02-2008, 01:24 PM   #3 (permalink)
Date registered: Apr 2008
Vehicle: 2005 C230 SS
I think it may also be related to washer fluid...I know mine went on when the washer fluid was low.
steveaustin is offline   Reply With Quote
"bulb out" warning light staying on. evilzee28 W124 E,CE,D,TD Class 15 12-28-2007 02:43 AM
SRS warning light staying on, 1998 SLK 230 scouse R170 SLK Class 9 10-14-2006 07:58 PM
SRS warning lamp elevinsp W203 C-Class 0 05-22-2005 11:32 AM
Lamp Out Warning alex lynch W163 M-Class 1 01-31-2003 02:54 PM
Low coolant lamp Shah R170 SLK Class 6 01-07-2001 04:40 PM
