» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-27-2008, 09:42 PM   #1 (permalink)
Date registered: Jul 2007
Mirror replacement, different connectors.
My right mirror got smashed in a parking lot. I ordered a new one and received it today.
The connector at the rear is different even if the part numbers match.
Is it that they decided to bypass this connector and that the new mirror connects directly in the door? In another words, should i try to splice and solder the wires, or open the door panel to connect it directly inside the door.
I tried to post a picture below... not sure if it'll work.
Thanks.
http://bp2.blogger.com/__l2A5IdxnOI/...0/P1000066.JPG
avecuny is offline   Reply With Quote
Old 06-28-2008, 02:51 PM   #2 (permalink)
I opened the door panel, and i figured it all.
As i tought, a connector was removed from the design. The mirror now connects directly inside the door.
The picture below shows the wire harness that's not used anymore.
outside mirror lens replacement p100 W126 S,SE,SEC,SEL,SD,SDL Class 4 04-06-2008 07:10 PM
Pass. mirror replacement mpower472 W219 CLS Class 2 08-13-2007 08:26 AM
Mirror LED replacement David's 2002 ML 320 W163 M-Class 1 06-22-2007 07:46 AM
Need help on a Right mirror replacement. sc_mopar General Mercedes-Benz 0 08-31-2005 12:28 PM
replacement rearview mirror? sashae W202 C-Class 0 11-13-2002 04:09 PM
