Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-27-2008, 01:43 PM   #1 (permalink)
Date registered: May 2008
LIMP MODE
OCTOBER 2001 C220 CDI
The other day my car went in to limp mode (2nd gear only) tI ook the car to the local garage for a diagnostic check came up, code No. P2201 came up which it said it had STORED. Once the code was clear car ran fine, only drove it home 8 miles from the garage, I don't want to keep on using the car until I know what the fault is or what caused the fault code. Really I need to know what the problem is with the car.
To let you understand the nearest Merc dealers is over an hours drive away.
So I need any help I can get.:crybaby2:
Thanks in advance
V-TECH
V-TECH is offline   Reply With Quote
Limp Mode noelchambers R170 SLK Class 4 08-18-2008 02:27 PM
LIMP MODE djblu R129 SL Class 12 08-14-2007 06:21 PM
HELP!! .. limp mode! BenzSLK230 R170 SLK Class 7 06-12-2006 10:23 AM
limp mode??? Dolphin27 R170 SLK Class 1 01-04-2006 04:02 PM
What is "limp mode"? xraider W202 C-Class 1 02-23-2004 06:20 AM
