Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-26-2008, 08:26 AM   #1 (permalink)
Date registered: Jun 2008
2002 C230 Coupe brake upgrade
Hello everyone,
I have a 2002 c230 Coupe which I just upgraded to a 2007 C230 sports brakes I found used, it seemed to be a direct bolt on but I am having the ABS light come on and it also disables the BAS and electronic stability. I need help diagnosing the problem. If anyone know how to fix the abs light issue I would greatly appreciate the help.
Thanks
evillarr is offline   Reply With Quote
Old 06-26-2008, 01:13 PM   #2 (permalink)
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup
Originally Posted by evillarr View Post
Hello everyone,
Thanks
Sounds like maybe you got some bubbles in the line.
Clearing bubbles from the ABS requires DAS to pulse the ABS pump.
I run AMG brakes, and never had ABS errors.
I get ESP errors but thats related to a sensor, and I really don't like ESP, so I don't bother fixing it.
2002 Orion Blue C230 Coupe
Auto-Pano-Leather (Oyster)
Audio 10
AMG; front Swaybar-Wheels- Front Brakes
Supersprint Header-ASP Pulley-Remus Muffler
TEIN SS Coilovers - H&R rear sway 19mm
Clear sides- 2005 tails- Tinted Windows
Clear Fogs- Bi-Xenons
C230 Sport Coup is offline   Reply With Quote
Old 06-26-2008, 09:13 PM   #3 (permalink)
C230 Sports Coup,
I have tried bleeding the brakes and abs block several times. I have noticed that at startup the abs light will sometimes stay off but when I brake I feel the abs engauge and when I speed up the abs light comes on again. The only parts I upgraded was the front rotors and brake calipers from a 2007 sports c230, do i need to upgrade any other parts in my 2002 c230 brake system?
Headlight upgrade for C230 Coupe Guest (MBNZ) W202 C-Class 2 08-29-2008 06:08 AM
2002 C230 C32 brake upgrade SZABO W203 C-Class 6 02-03-2008 11:44 AM
Which brake pads for 2002 C230 Coupe? nilknarf W203 C-Class 2 08-01-2006 08:31 PM
Eibach Springs from 2002 C230 Coupe > Can I use it on my 2002 C240 AMG702 W203 C-Class 1 08-29-2004 10:12 AM
C230 coupe stereo upgrade paulshu W203 C-Class 3 10-22-2003 08:15 AM
