Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-25-2008, 10:57 AM   #1 (permalink)
Chuck V's Avatar
C240 hard to start
Got a 2003 C240 4MATIC. for the last several months I've had an intermittent problem starting the car. The battery is just fine, just put a new one in as the old one was five years old and I had the battery die on my 2002.
When I turn the key, sometimes it cranks and starts, sometimes it will crank for less than a second and not start, sometimes it does nothing. I've had it to the dealer twice. As expected, I keep getting "unable to duplicate problem".
I've already paid $160 to have the flywheel/starter teeth lubricated. They claim that can cause my symptoms. They also tell me that there are no service bullitins on this. Don't know if this is relevant but had the radiator changed and the transmission flushed maybe three months ago. I had one for bad Valeo radiators and was getting rough shifts and tourqe convertor shudder pretty bad before they were able to replicate problem on second or third visit for same.
Any ideas?
Chuck V is offline   Reply With Quote
Old 06-25-2008, 06:33 PM   #2 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Any ideas?
OK hold it; the car doesn't CRANK? That is.....it does not turn over?
It's like completely dead? No sound, nada, nothing, zilch?
Or it does not turn on?
It just spins and spins?
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 06-25-2008, 10:35 PM   #3 (permalink)
Date registered: Mar 2006
Send a message via AIM to AcesHigh
I just brought my C240 in. My symptoms: gradually worsening (ie harder to start) starts, eventually to the point where it cranks but will not fire anymore. Not exactly the same as you; but I replaced my crank positioning sensor (CPS), that didn't help, so I took it in and they found that the relays/fuse box in the back got wet somehow and fried the electronics back there. I had a trunk leak.
But if it cranks but is not firing, it's probably the fuel pump or relay. (and or wiring to those things).
AcesHigh is offline   Reply With Quote
Old 06-26-2008, 10:53 AM   #4 (permalink)
Chuck V's Avatar
So far it cranks and starts eventually. I haven't been stranded yet thought I've been worried. This morning on each turn of the key: click....rrrrrr......rrrrrr......click....rrrrr... ..rrrrr.....rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrvroooomm mmmmm!
It will crank but for less than a second or just click. Battery is fine. No other problems.
Its doing it most of the time now. Started out on infrequent so its getting worse. Last two trips to the dealer it didn't do it once.
Old 06-26-2008, 01:26 PM   #5 (permalink)
MBC240's Avatar
Date registered: Mar 2007
Starter?
Clicking is what happened when the starter on my Accord went bye bye.
2003 Mercedes-Benz C240 5AT - 65.4k miles
1999 Honda Accord EX-L 4AT - 128.2k miles
1996 Honda Accord LX 4AT - 120.6k miles
MBC240 is offline   Reply With Quote
remote start in 01 c240 deesz Audio & Telematics Forum 0 10-30-2007 02:51 PM
2002 C240 won't start Edhead W203 C32 AMG, C55 AMG 1 01-20-2006 06:46 AM
sl500 cold start fine-short trip park restart rough idle hard start?? dpol1835 R129 SL Class 7 01-02-2006 07:33 AM
Cold Start? hard to start after temp drops Prissy6990 W126 S,SE,SEC,SEL,SD,SDL Class 4 02-15-2005 07:51 PM
Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 07:23 PM
