Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-23-2008, 11:10 AM   #1 (permalink)
Date registered: Jun 2008
Dented aluminum interior trim
Does anyone else have this problem. I have a 2006 and it seems like the slightest bit of pressure dents this trim. I would like to replace it with the newer 2007 wood or black trim. I do not want aftermarket I would like to replace with OEM trim. Any ideas on the cost? Has anyone done this.
grifier is offline   Reply With Quote
Old 06-23-2008, 11:59 AM   #2 (permalink)
BF_JC230's Avatar
Date registered: Oct 2003
Vehicle: 1980 w123 230 "Sport", 2005 w203 230 Sport
Send a message via AIM to BF_JC230
Expensive - Especially if you go new OEM from the dealer. Your best bet may come from a wreck - or contacting a wrecking / recycling yard. Potomac German Auto is showing a nice set on eBay right now (6/23/08) Item number: 180255758669...
DON'T FORGET ABOUT YOUR DOOR CARDS - UPPER TRIM AND WINDOW SWITCH SURROUNDS!
The "aluminum trim" is nothing more than aluminum foil wrapped around a PC/ABS plastic part. The actual aluminum I measure at about 00.030" - and it DOES ding easily - I already replaced my upper driver door trim due to a quickly released seat belt...
Good luck -
Jake
BF_JC230 is offline   Reply With Quote
Old 06-23-2008, 01:42 PM   #3 (permalink)
Install
THANKS for the info! How hard was the install on the doors?
Old 06-23-2008, 07:09 PM   #4 (permalink)
Black04C230's Avatar
Date registered: Mar 2008
Vehicle: 2004.5 C230 Kompressor
You also can find replacements on Ebay. I have seen a few on there.
2004.5 C230 Kompressor.
C55 Lip Spoiler, Roof Spoiler, 3 Fin Grill, Flat Emblem, Clear Corners, Smoked Tail Lights, Smoked Third Brake Light, and Window Tints.
Black04C230 is offline   Reply With Quote
Wood trim for Aluminum trim? kontradictions1 W164 M-Class 2 08-13-2007 02:02 PM
Aluminum Trim Polish Gregs300CD W123 E,CE,D,CD,TD,TE Class 29 08-20-2006 06:31 PM
Aluminum trim clearcoat Gregs300CD W123 E,CE,D,CD,TD,TE Class 16 01-05-2006 07:28 PM
Aluminum trim - ?? vdubpower W203 C-Class 3 11-02-2004 12:39 AM
C-Class 03 sport aluminum trim for laurel wood trim TILLMANN W203 C-Class 0 02-25-2003 12:14 PM
