Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-23-2008, 10:19 AM   #1 (permalink)
taxi615's Avatar
Date registered: Apr 2007
Vehicle: 2002 c230K black coupe
fuel gauge not working???
I was woundering...yesturday I was driving around and my fuel gauge stopped working. I went through all the fuses under the hood and in the trunk and found nothing had blowen. can someone help me out with this I would hate to run out of fuel on the road.
thanks
bilstein and eibach, azenis 225-50-16, K&N filter, boost and air/fuel meter, Phillips H7 4000K light all around. Tinted windows, ZEX 100 shot.
75 shot=1/4 mile: 13.961@107.76
comming up: ASP pulley, crank pulley, ECU flash (powerchip), PSS9 coil over kit, big brake system, sway bars all around, brake lines, remus with supersprint headers, 255lph fuel pump...maybe 17''.
taxi615 is offline   Reply With Quote
Old 06-24-2008, 08:44 AM   #2 (permalink)
taxi615's Avatar
ok I got the problem resolved I went to the gaz up and found the cap loose and when I started again it was fine so when you go to a service station make sure they put the gaz cap back on tight.
Old 06-24-2008, 10:13 PM   #3 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
Did having the gas cap loose set off CEL? I remember hearing that on some of the models it does. I forgot to put the cap back on once though, and no CEL. I was going to say it could have been your fuel sending unit when I first read this. Glad you got it figured out. I didn't know loose cap would kill the fuel guage reading.
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 06-25-2008, 10:12 AM   #4 (permalink)
taxi615's Avatar
I didn't know that either but it seams that way
fuel gauge not working ! STEPH R129 R129 SL Class 10 03-08-2008 11:43 AM
Fuel gauge not working rongotti W163 M-Class 20 06-11-2005 12:20 PM
fuel gauge not working tony1 W203 C-Class 4 05-11-2005 04:37 PM
fuel gauge not working tony1 Audio & Telematics Forum 0 05-05-2005 03:19 PM
my fuel gauge stopped working kourosh W126 S,SE,SEC,SEL,SD,SDL Class 4 10-30-2003 12:49 PM
