Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-19-2008, 10:18 PM   #1 (permalink)
ssounit's Avatar
Date registered: Jun 2008
Vehicle: '07C350 Iridium Silver
Re-drill Cross drilled rotors?
Hi all,
I'm a newbie to this forum but I have learned a wealth of knowledge so far. I've done a search for my question but have not been bale to find an answer. It's time for my front brakes to be serviced ( I have 23k on OEM pads and rotors) and they are cross drilled. My local delaer is telling me that I don't need the rotors turned but that they do need to re-drill the cross drilled holes because of brake dust build up. Does this sound right? I've never heard of such a thing and I'm hoping to get some feed back from all the informative people here. I appreciate your responses. Also should I stay with OEM replacement pads or do dealers carry other brands that don't produce so much brake dust. This is the first vehicle I have had that has produced so much brake dust.
'07 C350 Iridium Silver stock except for 4 fin black grill and flat hood badge.
Orange County, CA.
ssounit is offline   Reply With Quote
Old 06-20-2008, 12:09 AM   #2 (permalink)
Chris Gaines's Avatar
Date registered: Feb 2008
Vehicle: 2005 MB C230
The dealer needs to put it down
Just buy new oem or aftermarket rotors
2005 MB C230K
Chris Gaines is online now   Reply With Quote
Old 06-20-2008, 06:06 AM   #3 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
chris gaines, sorry...but you should put down the crack pipe too.
at 23k miles he doesn't need new rotors...just pads. brake dust clogging the holes are normal. just leave it alone. if you really want to clean them out take a screw driver and go at it.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 06-20-2008, 06:22 AM   #4 (permalink)
ssounit's Avatar
FrankW..... Thanks for the advise. How do I know if I need to have the rotors turned and new pads, or leave the rotors as they are and just put on new pads?
Old 06-20-2008, 10:21 AM   #5 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Rotors should be mic'ed to see that they are thick enough according to spec for that rotor. If they are, and they are not badly grooved or warped you can just put pads on. If you switch pad formulations you should at least clean the surface with emery cloth and brake cleaner. What may happen initially is it may squeal for a few weeks until the pads mate to the surface of the rotor.
Old 06-20-2008, 01:39 PM   #6 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
I have 25k miles on my car and do not need rotors or pads but I don't drive my car that hard at all. You def do not need new rotors with under 30k miles. Never heard of redrilling cross drilled rotors.
Tri-Star is offline   Reply With Quote
Old 06-20-2008, 08:20 PM   #7 (permalink)
jrsmith_68's Avatar
Date registered: Mar 2007
Vehicle: 2007 C350
I have to agree with FrankW. The cross drills on my rotors were also plugged, but only on the inside of the rotor. I did use a drill to open mine back up, I was not removing any metal, just the build-up. Took all of about 2 minutes.
jrsmith_68 is offline   Reply With Quote
Old 06-21-2008, 06:05 AM   #8 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Originally Posted by ssounit View Post
Hi all,
Now hold on; I had some cross drilled rotors years ago, at least from memory, I thought it was Verbotten to redrill your crossed-drill rotors? Isn't that still the
standard? I could have sworn I read in the mfg. installation instructions it
is Verbotten.
Anyway; if you have build up, why not just clean out the plugged up holes?
A low speed drill, metal drill bit, PERFECTLY fitting the holes, you can clean up
those plugged up holes.
Then put on a buffing emery pad on the drill and buff out the glazing, dirt, minor
scratches etc.
This is an easy easy fix. Basic Maintenance 101.
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 06-21-2008, 10:11 AM   #9 (permalink)
Ok Frank so he does need to re-drill the holes ? I dont think so
and second you dont just put new pads on old groved and worn rotors.
The safest thing is to buy new rotors then you have a smooth surface between the pads and rotors
That is what the pipe is for Sir
guess it just comes down to doing it right or half assed
Old 06-22-2008, 02:26 AM   #10 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
Simply put, you aren't really "re-drilling" the rotors. You are simply using a drill bit to clean out the existing holes. It makes perfect sense that the holes clog up with brake dust, just as much as the groove in the pad has a tendency to become packed with dust.
Whosdis is offline   Reply With Quote
Re-drill Cross drilled front rotors? ssounit W203 C32 AMG, C55 AMG 2 07-01-2008 12:17 PM
NEED NEW ROTORS, CROSS DRILLED clk4302002 R230 SL Class 2 06-28-2007 01:08 PM
cross drilled rotors em17henry W163 M-Class 10 10-12-2004 06:37 PM
Cross Drilled Rotors anyone have them orion W208 CLK Class 2 12-19-2001 11:44 PM
Cross Drilled Rotors, anyone done them? orion W208 CLK Class 4 09-26-2001 10:51 PM
