Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-19-2008, 05:58 PM   #1 (permalink)
Date registered: Jun 2008
c240 Installing New Trunk Latch
Hello!
The trunk latch on my 2002 C240 broke; I purchased a replacement latch and started installing it but I've encountered a problem. One of the electrical connections is a 3-pin- the new part is a 4-pin. It came w/ a 4 pin adapter. I've tried inserting the 3 wires into the 4 pin adapter in various configurations and can't seem to make it work. The alarm will go off (which I believe is the white wire) but I can't get anything else to work when I plug in the other wires (brown & brown/yellow). When I pull the trunk handle, I get nothing.
I'm not sure if I'm just not plugging these wires in right (anybody have a diagram for this?), or if I've done something else to make it not work.
Any suggestions?
Thank you!
leanna1123 is offline   Reply With Quote
Old 06-20-2008, 03:19 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
on the new connecter, the first slot isnt used, which is pin 1. only slots 2,3,4 are used. if you hold on till later, i can pull up the wiring diagram and get you the wire configuration. more then likely you just have the wires in the wrong slots. call me around 10 or so and ill help you, pm sent.
Streetglower is offline   Reply With Quote
Old 08-18-2008, 01:44 PM   #3 (permalink)
Date registered: Jun 2003
Vehicle: 2002 C320 Wagon
Any general guidance/instructions for replacing the trunk latch? I am contemplating doing so on my 02 C320 Wagon.
Kal
Kal Rubinson is offline   Reply With Quote
Old 09-11-2008, 11:44 AM   #4 (permalink)
Date registered: Sep 2008
c240 Installing New Trunk Latch - diagram request pls
will you be able to provide me a diagram of the electriacal wiring from 3pin to 4pin connector? Thank you.
alfua is offline   Reply With Quote
230SL trunk latch TWEngel Vintage Mercedes-Benz 2 05-20-2008 07:20 PM
pin out for trunk latch kennyd W203 C-Class 0 03-31-2008 11:27 PM
Trunk latch stuck Jennifer Shea W208 CLK Class 7 01-29-2008 06:45 AM
Trunk lid latch StuttgartStud R170 SLK Class 7 10-12-2004 02:47 PM
Trunk Latch Xylocaine W163 M-Class 2 07-21-2003 08:28 AM
