Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 06-15-2008, 02:26 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 2006 C350 4-matic (No Modifications)
Send a message via AIM to acery
Brake Grabbing?
When backing out and turning the wheel slightly, the brakes seem to engage on their own. The same thing happens when I turn right/left from a complete stop. It's almost as if the car is fighting me. I'm starting to wonder if this is happening when I'm up to normal speed because my gas mileage is horrible. The engine hangs on shifting, etc.
The turns are under normal driving conditions. I'm not driving in a manner that would make the computer compensate for over steer, etc.
Thanks.
acery is offline   Reply With Quote
Old 07-08-2008, 06:52 AM   #2 (permalink)
Well, I took the car in for its service A at 33,000 miles. It turns out it was the transfer case. Apparently, every other problem the car had was related to that also since it was purchased (new w/5 miles on the OD)
Old 07-08-2008, 10:55 PM   #3 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
Did you get it fixed under warrenty, or not? Total price?
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 07-09-2008, 01:04 PM   #4 (permalink)
It was done under warranty. I had complained about "under performance" every time I brought the car in for its services. Whether it was Service A, B, for a recall and a faulty oil sensor.
I have the same make/mileage so I had a benchmark to compare the vehicles. I guess it got to a point to where the tech could finally hear something.
The invoice did not mention a price as it was all warranty work. I could only assume the base price is somewhere around 1800 to 2000 for the part. They had to drill out the bolts and replace several parts that attach to the transfer case.
I'll post up exactly what they did when I get home and find the paperwork.
QUESTION on my recently installed Brake Rotors, Pads, Brake Lines, Brake Flush babyboigsxr W208 CLK Class 5 03-28-2008 11:37 AM
grabbing brake pedal feel vinceching GL Class 0 10-01-2007 12:59 PM
grabbing brake pedal feel vinceching W164 M-Class 4 09-28-2007 09:23 PM
Stupid brake question.... how thick is the oem front/back brake pad?? ometofu W163 M-Class 7 07-11-2002 07:23 AM
Problem Fitting Rear Brake Disc Rotors over Parking Brake Shoes? Guest (MBNZ) W124 E,CE,D,TD Class 7 04-03-2002 09:22 AM
