Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 05-07-2008, 06:12 AM   #1 (permalink)
Eesjunin's Avatar
Date registered: Apr 2007
Vehicle: 2002 Mercedes C320
Lightbulb The VDO display in warm/hot weather
Not sure that i have mentioned it before, but it seems like its a bit worse from last year. Only does that when its warm/hot outside.
Any idea? I mean the ultimate solution, of course, is replacement.
Anyone else having, or heard about this?
Thanks!
See below what i mean
Custom painted front lense covers and grill; Tein Lowering springs; Custom Flowmaster dual exhaust; K&N filters; de-badged; Euro style rear window spoiler; AMG trunk lip
Riegers body kit;
Eesjunin is offline   Reply With Quote
Old 05-07-2008, 04:58 PM   #2 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
Yes, it is a common problem with the displays as they get older. I tried covering it with a sheet of cardboard to block from any sunlight thinking that might help, but it didn't. The only solution is a replacement. That, or you can just store the vehicle in a cool area. At least yours doesn't seem that bad. Mine gets a lot worse.
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 05-07-2008, 05:29 PM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Looks like the pixels are going bad.
JOE55 is offline   Reply With Quote
Old 05-07-2008, 05:46 PM   #4 (permalink)
MBC240's Avatar
Date registered: Mar 2007
Boy do I love my extended warranty!
Going to get this fixed before I sell the C240.
Your MPG's look far better than mine!
2003 Mercedes-Benz C240 5AT - 65.4k miles
1999 Honda Accord EX-L 4AT - 128.2k miles
1996 Honda Accord LX 4AT - 120.6k miles
MBC240 is offline   Reply With Quote
Old 05-07-2008, 06:28 PM   #5 (permalink)
Eesjunin's Avatar
I actually get up to 33 mpg's on highway
I had extended warranty till 100K but its been gone now that i got 130K
ANy idea where i can find a used VDO, and do i have to go through dealership for the whole re-programming deal?
Old 08-02-2008, 10:58 PM   #6 (permalink)
Date registered: Jun 2008
Vehicle: 2004 Mercedes C230 Kompressor Sedan
I have this exact same issue. I should have had it repaired before my warranty expired...
mystery905 is offline   Reply With Quote
Old 08-04-2008, 08:33 AM   #7 (permalink)
Eesjunin's Avatar
thats for sure...i am going to hold off on that since its ok when its cold...so not too concern yet, but when they start to disappear and not appear again then will spend some $$ on it
Old 08-04-2008, 08:41 AM   #8 (permalink)
Date registered: Jul 2003
Vehicle: 2003 C230K 6spd, 1996 Integra RS
same is happening to ours.. oh well.
reno
- '96 Integra RS (mine)
- '03 C230K C-Coupe (hers)
reno96teg is offline   Reply With Quote
Old 08-04-2008, 03:49 PM   #9 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
use a sun shade when park the car in the sun. it should help prevent the pixel dying quicker.
if you don't have the extended warranty go to a junk yard and look for a VDO that doesn't have the same issue, but you will need to take both VDO apart and swap parts because once the dash is used they cannot be programed for another car. you will need a new dash if you want to replace it.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 08-05-2008, 06:00 AM   #10 (permalink)
Eesjunin's Avatar
Thanks Frank, i saw that somewhere else..and its a good point!
The sun shade doesnt really do much, been using since day one....still happening
WARM (weather) start issues? smallfence W123 E,CE,D,CD,TD,TE Class 7 05-31-2006 06:58 AM
ML NOT STARTING IN HOT WEATHER OR HOT ENGINE!!!!! jmarenas W163 M-Class 11 09-06-2005 04:42 PM
Finally Some Warm Weather!!!! SIlver_Lana R171 SLK Class 23 03-09-2005 02:20 PM
Feeding data to the VDO display sfopeano Audio & Telematics Forum 2 09-23-2004 01:10 PM
Finally some warm weather ! Thomas_S G-Class 6 05-02-2003 05:51 PM
