Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-30-2008, 04:17 PM   #1 (permalink)
Date registered: Oct 2007
w203 problem need help!!!!
Hello everyone, my 2004 c320 sport is acting up and I need your help!!!!
During acceleration the car hesitates and when you keep at lets say 50mph hesitates like some one is shutting the fuel on and off and I got a humming noise that I can feel thru out the car. Now I took the car to The German auto shop in Edison NJ. They saw what the car was doing but it had no codes and they couldn't find the problem the Trans fluid looks good (no contamination).
Anyone here have any idea what this problem may be..?
speedracer1098 is offline   Reply With Quote
Old 04-30-2008, 09:42 PM   #2 (permalink)
bringing the car to Ray Catena stealership tomorrow lets see what they say
Old 04-30-2008, 10:54 PM   #3 (permalink)
Date registered: Sep 2007
Please share what they tell you, mine has same similar symptoms
ruizmilton is offline   Reply With Quote
Old 05-01-2008, 07:38 AM   #4 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
Lately all i've been reading about is c320 problems which is not making me happy. Maybe it is the fuel pump or injectors?
Tri-Star is offline   Reply With Quote
Old 05-01-2008, 04:11 PM   #5 (permalink)
Date registered: Mar 2007
The trans fluid looks good? Did they perform a glycol test? I cant tell you whats wrong since i havnt driven the car. But from your complaint with the "humming" noise thru out the whole car, it could be your tq converter staying engage. When does the humming noise occur? from 1500-2000 rpm?
Motioneffects is offline   Reply With Quote
Old 05-01-2008, 07:09 PM   #6 (permalink)
Motioneffects ...yes the dealer run out time checking the car up today, and
The shop foreman took a test ride with me. He believe it’s the torque converter
...yes the car those the humming under a load and yes after the car goes thru the gears and you try to maintain speed loading the engine the humming and vibration begin......now how much are we talking here for a torque converter
Old 05-01-2008, 07:17 PM   #7 (permalink)
Old 05-02-2008, 04:55 PM   #8 (permalink)
Well, not being able to drive the car, its hard to go further and diag the problem. What will happen next is,
1) dealer will reset the adaptation to see if the issue will go away. if it does, you will need a trans control module. $500-600.
2) if it does not go away, they will perform the glycol test. if the test shows ~100 ppm or less glycol content(i think, cant remember the numbers) you are fine. if its more like ~200ppm, they will try to flush the system out and replace the radiator. if its more than 250ppm, than you need a new trans and tq converter. Keep in mind that if they say all you need is a flush and radiator replace, the problem will come back. I havn't seen a flush that worked!
3) if they find NO glycol in trans, then all you need is a tq converter. $1000 + ~4 hr labor
But it could be other issues totally different than what i described since i havn't driven the car.
Old 05-02-2008, 04:57 PM   #9 (permalink)
Which ray catena did you take it to? rt1 or union
Old 05-05-2008, 05:47 PM   #10 (permalink)
Motioneffects...the dealer did a glycol test ....fluid is ok but really dark need a change they say.....and they gave me a price on changing a torque converter for $ 1950 + tax ....Ray Catena in edison. I'm really disapointed with this car.
now should i just get a new trans control module..? the dealer did not mention reset the adptation control.
thanks Motioneffects.
w203 w271engine coldstart problem HELP!! cchenghuey W203 C-Class 3 03-26-2008 11:51 AM
w203 comand problem !!!!!! c200kSE Audio & Telematics Forum 7 03-19-2007 05:48 AM
W203 Aircon Problem sv4 General Mercedes-Benz 0 02-14-2007 08:33 PM
Help! Problem after fitting Bi-Xenon on W203 PaulsML500 W203 C-Class 3 11-30-2006 10:25 PM
Problem with epc in mercedes-benz w203 bosnia W203 C-Class 0 07-13-2004 01:59 PM
