Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-30-2008, 04:12 PM   #1 (permalink)
Date registered: Apr 2008
Unhappy HOW DO YOU REPLACE A CRANK POSITION SENSOR ON A 2001 MERCEDES C320
HOW DO YOU REPLACE A CRANK POSITION SENSOR ON A 2001 MERCEDES and WHERE IS THE SENSOR LOCATED
waldo0757 is offline   Reply With Quote
Old 05-09-2008, 09:49 PM   #2 (permalink)
Date registered: May 2008
Don't quote me as I am just taking mine to the shop tomorrow for the same thing, but I read it is on the very back of the engine, drivers side, follow the wires. The article also suggested to use good lighting as it may be hard to see
Blind Dragon is offline   Reply With Quote
Old 05-11-2008, 08:48 AM   #3 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
I've posted pics in the past, but yest, it's where the engine meets the tranny on the drives side at about 10 o'clock position if the flywheel is a clock. I't just one small bolt, unplug sensor, remove bolt, pull the sensor out, put new one in, tighen bolt, re-connect sensor, reset any OBD2 codes.
Old 05-13-2008, 08:21 AM   #4 (permalink)
Stealership charges to me = $110 for diagnostic to tell me that was the problem which I told them I thought it was when I went in.
Then $495 to replace the sensor
So over $600 in charges. I should have done it myself.
The good thing I guess is they found some cracked bushings and my rear seals had a slight leak
Crank Position Sensor dannydang W220 S-Class 14 11-03-2008 07:51 AM
crank position sensor T Hassan W220 S-Class 3 04-13-2008 02:13 PM
crank angle sensor or crank position sensor Gwagensofli G-Class 1 07-31-2007 04:37 PM
Crank position sensor, where is it? starscream W140 S-Class 3 10-03-2006 08:55 AM
Where is the Crank Position sensor? Ben Kokes R170 SLK Class 2 05-10-2002 06:26 PM
