Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-30-2008, 04:35 AM   #1 (permalink)
2002c230's Avatar
Date registered: Jun 2007
Vehicle: 02' C230 Kompressor Sport Coupe (M111)
Clicking sound while driving
I sometimes get a loud clicking sound while driving my coupe. It is coming from somewhere by the front of the vehicle. Clicks faster as the vehicle increases speed. Ruled out a bent wheel as the cause, because it is not always present. Thinking that it is likely the drive shaft insulation as discussed on a few other threads, but the strange part is the sound seems to quiet, or stop, after applying the brakes. Any ideas?
My Car; 02' C230 Kompressor Sportcoupe [115,000 Miles]
Modifications: ASP Overdrive Pulley - NGK Iridium IX Sparkplugs - Kompressor Silencer Removed
---------------- Clear Side Indicator Covers
My Website; Internet Database Website
My Forum; I.D.W. Forum
2002c230 is offline   Reply With Quote
Old 04-30-2008, 07:36 AM   #2 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
Do you have stock lug nuts or aftermarket ones? If they are too long they could be hitting something in your hub causing the clicking. Just an idea.
Tri-Star is offline   Reply With Quote
Old 05-05-2008, 10:28 PM   #3 (permalink)
2002c230's Avatar
I have the OEM wheels, and lug nuts. Also, as I said before the sound is not always present, so that couldn't be the cause. Do you know if the drive shaft insulation is a permanent sound until corrected, or can show up occasionally? The sound gets decently loud sometimes, and then other times it isn't noticable.
Old 05-06-2008, 07:50 AM   #4 (permalink)
Date registered: Jan 2007
check the torque on your links/control arms/bars, etc. Mine was a little loose with the stockers (before i upgraded), or you might need new bushings.
Renntech:evosport:REMUS:BRABUS:Lorinser:timeattack_________________c320 coupe on benzworld
advans is offline   Reply With Quote
Clicking Sound olat320 W163 M-Class 6 04-15-2008 09:55 PM
clicking sound? lilbilly11 W126 S,SE,SEC,SEL,SD,SDL Class 7 12-26-2006 02:18 PM
Another clicking sound ski W203 C-Class 5 12-22-2005 06:59 PM
oh oh: clicking sound on take off... 560DBleu R129 SL Class 3 09-26-2005 08:46 AM
Help! Clicking driving me crazy! Seeley R170 SLK Class 10 06-28-2005 05:16 PM
