19x8.5 in the front 19x9.5 in the rear the ofset is et 38+ or whatever.
my old wheels fit like just barely with a 35 offset all the way around... these wheels though are like SUPER SUPER SUPER close... like they look like they will rub the shock in the front...
If I put spacers on the front it will push me out a little bit and give me clearance right ?? so that I can use the new wheels... How much spacer do you think is needed ?? 10mm 15mm 20mm ??
As it is right now, when the wheel is straight I can slip my fingers between the inside of the rim wall and the shock. If I turn it all the way to either side It pinches my finger and they touch.
I think I fucked up and I might have to return the wheels but I dont know if they are guna let me... If I can just get spacers I would love to put the new wheels on...
Anyone Got spacers ?? where did you get them ??
What size do you think would make me clear the gap??
I think I rushed it cus I was excited for summer... damn it.
2005, C240 4-Matic: Rennen RC2 19's in black with polished lip and rivits Staggered (235/35/8.5 Front 265/30/9.5 rear) with General Exclaim UHP Rubbers -- HID black housing Projectors at 8000k -- Clear side markers --- Flat Brabus Hood badge -- CL Grill all black --- Tints 15% all the way around -- Brabus Door Pins/surrounds
If I assume your old wheels were the same width as your new ones, then you need a 3mm thick spacer. I have not seen one that thin, but I have seen this one which is 5mm and it is hubcentric which is nice.
how come you Using Staggard wheels on a 4Matic ???? i think you might have Problems be careful but a picture of the wheel will help more . you maybe able to use a 5mm Spacer and longer Lugs the right offset for the front should be around 32 offset and Below to clear without spacers what size Tires you have?
Spacers also cause Vibration... next time research your wheels before you buy...
yea I thought they were 35 offset and that wouldnt have been bad. thats what I had and it worked... but they are 38 offset so its more.
I was thinking the reverse... that the higher the offset the further from the hub but the higher the offset it seems the closer to the hub it is huh??
So with 38offset +5 mm would make me 32 offset ?
or do I have this all wrong
[quote=Spacers also cause Vibration... next time research your wheels before you buy... [/QUOTE]
What do you mean Cause Vibrations ?? like they will give me shimmy ?? if this is the case the wheels are going back and I will put my orignals back on.
I don't understand why you just didn't buy spacers like I told you initially before getting new rims? 5mm spacers should be fine. I'm running a 32 offset. Let me know how everything goes. I'll be out on long island this weekend.
I am surprised that you went and got new wheels with the incorrect offset all over again joey. They better look freaking nice for all the freaking trouble you are going through to get them to fit.
H&R springs, Koni Sport adjustable shocks, Pioneer Avic D3, JL Audio 200/1 driving 10 inch sub, JL Audio 300/4 driving component set up front and two 6 inch two way outback, flat MB emblem, S class tail lights, clear corner markers, chrome amg tips, 19x9.5 in back and 19x8.5 in front.
once I get them set up you will see, there like yours but black multi spokes with silver rivits between them and a dish and a half...
I just fucked up because when I ordered them for some reason I was thinking that my old wheels were +35 and they were close... I was thinking +38 would make them furthar away (the oppisite is true) like a dipshit I wasnt thinking and I forgot the stock offset is +32 not +35... At the moment I was thinking ok so 38 is more then the stock 35 and it will be a lil farther away which will be good because it makes me nervous there so close....
I dont know it was one of those impulse buys that I am starting to regret. I might have to return them since they are still wrapped up... Blah I am a dummy sometimes.
Two things in this world are like kryptonite for me
just ask PJay hahah
Girls and Cars.
I want wayyyy to many and I do stupid shit around both of them hahahhahaha
p.s. good looks on the link, once again you're the man.
Return the wheels you just bought, buy spacers and save yourself a lot of money. The rims you have are nice. There's no need to replace them. My .02 anyway.
