Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-26-2008, 04:25 PM   #1 (permalink)
Date registered: Sep 2007
Need Help! No throtle response...
For whatever reason my car (2004 C230) seems to have gone to limp home mode about two days ago, whenever that happens I just stop the engine and re-start and continue, but today after driving more or less ok once I stop at a traffic light, when I depress the throtle pedal RPM's do not pick-up at all!!! car just doesn't move!!! What can I do at least till I can get it to my mechanic???
ruizmilton is offline   Reply With Quote
Old 04-27-2008, 12:45 AM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
replace the throttle pedal assembly. $120 ish from dealership.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 04-29-2008, 03:53 AM   #3 (permalink)
Date registered: Apr 2008
have done throttle lots before, sounds the same prob. if you like press the button under the pedal which is the kick down or full throttle button, then try and drive away, if it does the same then the acc. pedal is at fault
milo16d is offline   Reply With Quote
Old 04-30-2008, 06:22 AM   #4 (permalink)
Thanks, I will check the throtle pedal, but I think that is not the problem, this condition only happens after the engine goes into what seems limp home mode where rpm would increase very slowly and with almost no power, then after it reaches about 3000 rpm's then it just does not want to accelerate anymore at all.
throtle valve gravel W163 M-Class 1 09-28-2007 07:24 PM
STUMPED: strange throtle response - vacuum issue? Goldenvoice W123 E,CE,D,CD,TD,TE Class 30 07-15-2006 11:49 AM
throtle adaptation rab538 W163 M-Class 0 05-12-2006 12:16 PM
throtle linkage bracket Kuzuki G-Class 0 09-09-2004 01:31 PM
Got another response from Colgan........... Bruce R.- DC R170 SLK Class 4 04-27-2002 11:37 AM
