Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-25-2008, 05:26 PM   #1 (permalink)
Date registered: Apr 2008
Vehicle: 04 C230K
New Member and an issue with getting my car chipped
Hey guys, first post. My name's Clint and I bought an 04 C230K about 7 weeks ago when I got back from Iraq. Pretty nice car, only 36k miles when i bought it and interior/exterior were pretty much perfect.
Anyway, I had my ECU reprogrammed at Speed Tuning (Stage 2 tune). I've been talking to Oliver quite a bit up there. Soo, I took it out Monday night, got it back earlier today, hooked it up, and tried to start the car. First try it cranks, fires, stutters bad, dies. Then it just cranks the next few tries. I unhook the battery for a few minutes, reconnect, crank it over, it fires and then stutters and dies. It only cranks now. No spark and I can't tell if it's getting fuel or not.
I've checked all of the fuses in the engine compartment. All are good. The three for engine electronics (48, 53, and 54) check out good and are getting 12.2V.
Before I send it back tomorrow should I check anything else or try anything else? I have a pretty good background with EFI systems (I've built one) so I'm game for anything within reason. I don't have an OBD-II scanner, though.
This thread is not to point fingers, so please don't get me wrong there. Oliver at Speed Tuning has been very helpful and he seems like a knowledgeable person and has already told me that he'd check out the ECU when I sent it back. I'd just rather not have to send it back and just drive my car, I'm sure all of you understand.
phate is offline   Reply With Quote
Old 04-26-2008, 03:47 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
good luck getting it solved. you would hope it wouldn't happen, but ecu might be fried. OR they've just f-ed up on the tune.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 04-28-2008, 05:57 PM   #3 (permalink)
Vehicle: 04 C230K
They just received it today and did some troubleshooting with it. He said it reverted to a wrong setting and they don't know why (it's not fried so that's the good news). They have to find out why it did that and then they're loading in the new fuel/timing maps again and shipping it out tomorrow. Hopefully I'll be running again on Wednesday.
Old 04-28-2008, 08:14 PM   #4 (permalink)
jrsmith_68's Avatar
Date registered: Mar 2007
Vehicle: 2007 C350
Once you get it installed and running correctly, do you plan on getting it dynoed to see if your gains are real? Just curious.
jrsmith_68 is offline   Reply With Quote
Old 04-28-2008, 09:02 PM   #5 (permalink)
Vehicle: 04 C230K
Nah, no dyno time for me. I'm going to head over to the local strip and see what it'll run in the 1/4. Dyno's are nice for tuning and I don't really care about what kind of "horsepower #'s" the dyno shows.
Besides, two different dyno's will show two different readings so which one is right?
Where at in Illinois are you from?? I'm originally from just north of Champaign.
Old 04-29-2008, 07:34 AM   #6 (permalink)
Date registered: Aug 2007
Vehicle: C320 4matic
Send a message via AIM to Tri-Star
Did they just reflash your ecu or are there additional mods as well?
Tri-Star is offline   Reply With Quote
Old 04-29-2008, 10:52 AM   #7 (permalink)
Date registered: Feb 2006
Vehicle: 2002 C320; 17" AMG 5-split-spoke wheels with Michelin PS2 tires
[quote=phate;2857206]...when I got back from Iraq....
QUOTE]
Thank you for your service! I have nothing to add to this thread, but good luck getting your problem solved, and again, thank you for protecting us.
hyd003 is offline   Reply With Quote
Old 04-29-2008, 12:24 PM   #8 (permalink)
MJ50's Avatar
Date registered: Nov 2003
Vehicle: C240 & ML350
Send a message via ICQ to MJ50 Send a message via AIM to MJ50 Send a message via MSN to MJ50 Send a message via Yahoo to MJ50
have no idea who speed tuning is, but good luck!
2003 C240 done modding
2004 E55 MBenzNL, RENNtech pulley, ECU, VRP split cooling
2004 ML350 modded & sold
MJ50 is offline   Reply With Quote
Old 05-01-2008, 11:09 AM   #9 (permalink)
Vehicle: 04 C230K
Just an update: The ECU has been shipped from Speed Tuning and I should have it tomorrow. When they got it back and ran the diagnostics on it every setting was wrong and all of the fuel/timing maps were effed. No one seems to know why this happened. Oliver talked to some engineers in Germany about it and they said that the only thing that might have happened is that it came into contact with a powerful magnet(s).
So they have reset and reloaded the ECU with the correct settings and hopefully I will have it running tomorrow night. I'll post my findings at that point and will take it to the strip in a couple of weeks if all is well.
Tri-Star: it's just a flash, nothing else is being done to the car.
Old 05-02-2008, 04:56 PM   #10 (permalink)
Vehicle: 04 C230K
So I got the ECU back a little while ago and put it in. Was talking to Oliver while I did it to make sure that everything was in order. Didn't work. Have to get the computer(s) "realigned" they think. I have to get it towed somewhere that can run Mercedes diagnostics which is probably the dealer 45 miles away...Speed Tuning is covering the cost. I'm disappointed to say the least but I wasn't getting my hopes up anyway.
Anyone else chipped their car? Hetzle W140 S-Class 9 03-27-2008 11:49 PM
New member, quick question on starting issue bby2ks2k R170 SLK Class 2 01-18-2008 04:32 PM
New Member - Brake Noise Issue Bay Area Bolt W211 E-Class 7 10-28-2006 09:36 AM
Sept issue of Sports Car Int'l has big write up on AMG car testing.... Butch R170 SLK Class 3 08-19-2003 04:15 PM
500 miles on new car, and a fat stone chipped windshield! Any comments? Callme_Bwana G-Class 2 01-06-2003 08:54 AM
