Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-18-2008, 09:45 AM   #1 (permalink)
Date registered: Mar 2008
2006 C280 rubbing on 19''s
Hi all, i just put on my 19''s and the front seem to be rubbing, the tire size's are 235/35/19 in the front and 260/30/19 in the rear, the rims are staggered 8.5 front and 9.5 rear. when i turn left i can feel it rubbing or a clicking type noise. i am on running stock suspension.
Thanks,
merce-deez is offline   Reply With Quote
Old 04-21-2008, 06:54 AM   #2 (permalink)
Joey2Times's Avatar
Date registered: Jul 2007
Vehicle: 2005 C240 4-Matic
What offset are you using ?
and what MM lugs?
Clicking and rubbing are two very different noises...
Clicking like steady - as if you put a baseball card in the spokes of your bike like when you were a kid clicking - makes me think that your lugs are too long and hitting your e-break spring tensioners inside the hub this is NOT good.
Rubbing makes me think you have the wrong offset...
Where did you get your wheels?
2005, C240 4-Matic: Rennen RC2 19's in black with polished lip and rivits Staggered (235/35/8.5 Front 265/30/9.5 rear) with General Exclaim UHP Rubbers -- HID black housing Projectors at 8000k -- Clear side markers --- Flat Brabus Hood badge -- CL Grill all black --- Tints 15% all the way around -- Brabus Door Pins/surrounds
Joey2Times is offline   Reply With Quote
Old 04-21-2008, 11:08 AM   #3 (permalink)
yeah the fronts are taken care off, it was the tire weight. i was thinking off rolling the rear fenders and get spacers, dont you think the offset is to much for the rear ?
19'' CLK rubbing problem mortenso The Discount Tire Direct Tire, Wheel, Brake & Suspension 5 11-21-2006 04:28 PM
Tires rubbing in 95 C280 after lowered ... Help!! wkeyau W202 C-Class 2 06-25-2004 04:12 PM
Anyone here selling 17'' rims and tires. Would like to upgrade my 2001 16'' wheels. \M5 W163 M-Class 4 06-12-2003 08:22 AM
Rims Rubbing for C280 Sport osocold707 W202 C-Class 1 03-27-2003 05:54 AM
Rubbing on a C280 Sport Guest (MBNZ) W202 C-Class 3 08-02-2002 12:18 PM
