Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-17-2008, 09:20 AM   #1 (permalink)
Date registered: Apr 2008
Post C-240 DIY Help
Hello Forum ...
I have 02 C240 and just did Glorified Oil Chage B service for $$$ ! dealer told me that I need to flush Brake Fluid for $129, Coolant for $129 and Air and Oil Filter for $375.
I need your expert advise on ...
1) are these DIY stuff
2) can it be done through non-dealer shop
looking forward to hear from you
thnx in advance
Clown08 is offline   Reply With Quote
Old 04-17-2008, 10:42 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
Brake fluid is hygroscopic, meaning it absorbs water. The system should be flushed every two to three years to help prevent rust and brake fluid with water in it lowers the boiling point.
The coolant also needs to be replaced for two reasons. After a while, the coolant looses its anti-rust properties, and it becomes acidic, causing hoses and the like to become soft, which may result in hoses popping or splitting.
If you have good mechanical understanding, you should be able to do these jobs yourself. The only problem is finding someone who will dispose of the used fluids.
Also, an independant shop should be able to do this since it is a job that should be done on all cars.
Whosdis is offline   Reply With Quote
Old 04-17-2008, 12:19 PM   #3 (permalink)
thanks - looks likes its better for me to leave it for experts to do the job
Old 04-17-2008, 12:29 PM   #4 (permalink)
Joey2Times's Avatar
Date registered: Jul 2007
Vehicle: 2005 C240 4-Matic
Originally Posted by Clown08 View Post
Hello Forum ...
thnx in advance
I am not sure I understand you... at you saying that the dealership just charged you 375$ for a oil filter ? That they charged you 129$ to flush your breaks and 129$ to flush your coolant ??
So you just paid 633$ not including tax for three things? did they also charge you 80$ a quart for oil or something ??
I just had an OLF done had them pull off all four rims and give me anti cease on hubs and lugs and check the balance on them while they were off, they checked my breaks (I had not asked them but they told me what I had noted a week before hand when I did it myself) and they filled my break fluid because it was low and they filled my washer fluid cus it was empty (it took too of those jugs) and they gave everythign a once over because I am going on a road trip today. All together it cost me 108$
syn mobile 1 too
2005, C240 4-Matic: Rennen RC2 19's in black with polished lip and rivits Staggered (235/35/8.5 Front 265/30/9.5 rear) with General Exclaim UHP Rubbers -- HID black housing Projectors at 8000k -- Clear side markers --- Flat Brabus Hood badge -- CL Grill all black --- Tints 15% all the way around -- Brabus Door Pins/surrounds
Joey2Times is offline   Reply With Quote
Old 04-17-2008, 01:35 PM   #5 (permalink)
Yes above prices I mentioned is what they gave me (I have not yet done), so was not sure out of these which one are DIY types ...
Old 04-17-2008, 05:56 PM   #6 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
they can all by DIYed.
you can drain the brake fluid from one of the brake line at the caliper, but you gotta know what you are doing.
drain for the coolant is on the bottom of the radiator. probably better if you remove the bumper first so it's easier to work with.
oil change's just oil change.take off the underbody cover, drain the fluid, change the oil filter, re-fill the oil.
doing all these just make sure you have all the proper tools. if not or if you are not confident enough just leave it to a shop to do it. dealership always over charge you on labor.
I wouldn't do a coolant flush btw. a lot of times they use cleaners that are really abrasive in the system. you don't really want that to happen and causing future problems.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 04-18-2008, 07:12 AM   #7 (permalink)
thank you all for the valuable advise. probably I will leave it to dealer this time.... may be after reading on this forum more often I will get that confidence and tips for future oil changes
Old 05-20-2008, 09:58 AM   #8 (permalink)
ram_rtg's Avatar
Date registered: Feb 2008
Vehicle: JUL 2004 C200 KOMPRESSOR
Hey guys, just out of curiosity, is there a certain type of coolant needed for a C200K W203 or can I simply use any type? Thanks.
ram_rtg is offline   Reply With Quote
Old 05-20-2008, 10:44 PM   #9 (permalink)
When it comes to brake fluid, if it is a little low, it is better not to top it off, as it may only be low because of pad and rotor wear. If you top it off, when you do a brake job and compress the pistons back in the caliper, the excess fluid will spill out. Not only will this make a mess, but if you do not clean it in time, the fluid can eat at the paint. Unless you find a brake fluid leak, do not fill the reservoir.
Old 05-20-2008, 11:22 PM   #10 (permalink)
C230 Sport Coup's Avatar
Date registered: Feb 2007
Vehicle: 2002 C230 Sport Coup
Zerex G-05 or the Mercedes Stuff which many of us suspect of being the same stuff in a different bottle.
The are the only 2 approved for use in late model benz's.
Frank, what are you talking about pulling the bumper to drain the coolant?
HUH?
Yeh, you have to remove the front bottom pan.
Get it warm but not hot, cool enough that you can unscrew the fill cap.
Put a pan under the rad, then unscrew the red petcock on the bottom of the radiator and drain.
Tighten when done.
Refill, 50/50 coolant and distilled water.
Start with cap still off on top, run engine till hot while standing still, wait till the thermostat opens and then fill again. Now, cap it, Drive around the block, and fill again.
Done.
Oil changes are detailed around here and are easy.
Suction is approved as well, you don't have to go from underneath.
Brake fluid, I DIY everything, but this job I hate so it's worth paying someone.
If you have a lift it's not so bad, but with the car on the ground, draining fluid from each wheel, and having the right tools, and a pressurized fluid thing...
fuggetaboutit.
2002 Orion Blue C230 Coupe
Auto-Pano-Leather (Oyster)
Audio 10
AMG; front Swaybar-Wheels- Front Brakes
Supersprint Header-ASP Pulley-Remus Muffler
TEIN SS Coilovers - H&R rear sway 19mm
Clear sides- 2005 tails- Tinted Windows
Clear Fogs- Bi-Xenons
C230 Sport Coup is offline   Reply With Quote
Advice on DIY vs. Non DIY Repair Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 10 08-30-2008 11:58 PM
Is a 240 a 240 regardless? intruder W123 E,CE,D,CD,TD,TE Class 14 12-30-2007 09:49 PM
My C 240 patrikim W203 C-Class 2 12-10-2007 02:08 PM
replace rear subframe mounts - DIY or not DIY? philthompson W126 S,SE,SEC,SEL,SD,SDL Class 1 02-02-2007 07:40 AM
240 TD beakerboc W123 E,CE,D,CD,TD,TE Class 5 08-13-2003 05:03 PM
