Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-16-2008, 06:46 PM   #1 (permalink)
virgoe's Avatar
Date registered: Feb 2007
Vehicle: C280 2008, C180 Kompressor 2006 (SOLD), C230 Kompressor 1999, 190E 1986 (SOLD), 240D 1982 (SOLD).
Send a message via MSN to virgoe
Post Checking Brakes at the dealership.
Can anybody tell what the hell does the dealership do exactly when they check your brakes , i took in my Benz for an A service and i told them to check my brakes if they needed changing, and to my surprise they charged me just to check my brakes more than $50 c'mon i said check not change them. they told me they did some kind of a computer check on them, i really didn't buy that or is that true ????
virgoe is offline   Reply With Quote
Old 04-16-2008, 06:51 PM   #2 (permalink)
livefreeordie's Avatar
Date registered: Oct 2007
Vehicle: 02 SLK230 Komp. 08 Honda CRV
They inspect the pads and measure the rotors to see if they are within specs.
livefreeordie is offline   Reply With Quote
Old 04-17-2008, 03:04 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
pretty much. what i do is pull off one wheel on the front and rear and measure the pads and measure the rotors. sometimes i dont even bother to meausre when i can physically see the pads are almost gone or the rotors have heavy grooves in them. then its common sense.
Streetglower is offline   Reply With Quote
Old 04-17-2008, 07:13 AM   #4 (permalink)
Joey2Times's Avatar
Date registered: Jul 2007
Vehicle: 2005 C240 4-Matic
yea... I just look through my wheels.. I can see the pads good enough in the front, in the rear I took off a wheel and look and its fine...
You got raped on 50$ to check that... those fucks should take a look for you anyway on a service A.. At least if they were a quality shop they would. Oil Lube Filter - Check breaks and airbox filters - check all fluids - and anticease the lugs and hub.
I mean all they REALLY have to do is look at them when they are doing the anticease.
bleh, that dealership sucks.
2005, C240 4-Matic: Rennen RC2 19's in black with polished lip and rivits Staggered (235/35/8.5 Front 265/30/9.5 rear) with General Exclaim UHP Rubbers -- HID black housing Projectors at 8000k -- Clear side markers --- Flat Brabus Hood badge -- CL Grill all black --- Tints 15% all the way around -- Brabus Door Pins/surrounds
Joey2Times is offline   Reply With Quote
Old 04-17-2008, 09:23 AM   #5 (permalink)
Date registered: Jan 2008
In the U.S., A service includes inspection of brakes. You probalby just shouldn't have asked for anything extra.
Getting brakes done, when the brake light comes on (sensor on the pad will trigger this) is a good way to go cause you have a little life on the pad even when the light comes on.
2008 C300 Sport with P2 Package
mika911 is online now   Reply With Quote
Old 04-17-2008, 10:20 AM   #6 (permalink)
Vehicle: 2003 C240 4Matic
In my service booklet it tells me that at a Service A, they pull the right-front wheel and simply look at the thickness of the rotor and pads. Service B says they measure all four rotors and the pads.
Whosdis is offline   Reply With Quote
Old 04-17-2008, 05:58 PM   #7 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
+1...
you just paid the $50 for nothing.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 04-17-2008, 06:49 PM   #8 (permalink)
KompressorMonkey's Avatar
Date registered: Mar 2008
Vehicle: 2k2 c230 kompressor coupe
Send a message via AIM to KompressorMonkey
yeah that sucks its ok well atleast you learned a lesson ive learned plenty lol -_-
KompressorMonkey is offline   Reply With Quote
Old 04-18-2008, 06:29 AM   #9 (permalink)
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: Mercedes-Benz
Send a message via AIM to Mercedes Benz of Florida Send a message via Yahoo to Mercedes Benz of Florida
Sounds right; 50 clams
Trust me if they DID change your Brakes it would not be a measley 50 clams
It would have been between $400-$900 depending on how the wind blows
in your State.
Are you complaining about the $50?
Or the Safety Inspection?
Either way; they should have notified you it was $50 and they should have
notified you what a Brake Inspection consists of.
Are you saying you were NOT EVER aware of this?
Charles
Orlando, Florida
United States of America
Mercedes Benz of Florida is offline   Reply With Quote
Old 04-18-2008, 07:57 AM   #10 (permalink)
Derek Lecours's Avatar
Vehicle: B 200 & Audi A6
A or B or C service...it's just a quick way to take your money.
My first service was shown as the B service.
I changed the oil and filter before and tested the battery and lubed the hinges and all items listed.
I wanted that stamp in the maintenance book. So $370 later they gave me my stamp and weren't happy that I did the work before hand and I let them know I did it.
They added no parts to my car, no air or pollen filters, nothing.
They air gunned my wheels back on with 'some' bolts torqued to 160 ft/lbs instead of the 95 ft/lbs recommended.
Not all dealers are created equal. $ 50 bucks!! you got off lucky!!
Good Dealership/Bad Dealership Michael Pillay General Mercedes-Benz 6 11-10-2005 03:56 PM
2003 C230 Sedan brakes to 2004 cross-drilled brakes? aaronmarks W203 C-Class 1 10-05-2005 05:00 PM
Checking in..... Tubs300E W124 E,CE,D,TD Class 1 07-17-2005 08:50 AM
checking in janos_z W126 S,SE,SEC,SEL,SD,SDL Class 1 11-23-2003 08:32 PM
Upgrading to Brembo or Porsche brakes? I will buy your W202 AMG brakes from you! Guest (MBNZ) W202 C36 AMG, C43 AMG 1 05-11-2002 03:11 PM
