Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-16-2008, 08:57 AM   #1 (permalink)
Landshark_dg's Avatar
Date registered: Apr 2006
Vehicle: 2001 C320
transmission slipping sometimes when cold
Every now and then (usually in the morning after just strating the car) my transmission will slip when I step on the gas. Engine revs, and then maybe a couple seconds go by before the wheels start turning. Anyone have this happen? Almost got t-boned pulling out of my complex the first time it happened. Doesn't happen that often, but enough to be cause for concern...
Landshark_dg is offline   Reply With Quote
Old 04-16-2008, 06:52 PM   #2 (permalink)
virgoe's Avatar
Date registered: Feb 2007
Vehicle: C280 2008, C180 Kompressor 2006 (SOLD), C230 Kompressor 1999, 190E 1986 (SOLD), 240D 1982 (SOLD).
Send a message via MSN to virgoe
Had that happened to my old 190e , had to change the tranny after a year.... but i dont want to scare you but mine started that way, but it could be it needs an oil and filter change?
virgoe is offline   Reply With Quote
Old 04-17-2008, 03:02 AM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
first things first, you need to check the fluid level. a low fluid level can cause the tranny to slip and act crazy.
Streetglower is offline   Reply With Quote
Old 04-18-2008, 10:47 AM   #4 (permalink)
Black04C230's Avatar
Date registered: Mar 2008
Vehicle: 2004.5 C230 Kompressor
Mine is screwy too. Slips a little when cold, sometimes bangs into gears and shifts too late a lot. Just had to go take mine into the dealer this morning for the third time. I would go get it checked out asap.
2004.5 C230 Kompressor.
C55 Lip Spoiler, Roof Spoiler, 3 Fin Grill, Flat Emblem, Clear Corners, Smoked Tail Lights, Smoked Third Brake Light, and Window Tints.
Black04C230 is offline   Reply With Quote
32 Transmission slipping? HEX20 R170 SLK Class 12 08-08-2007 01:13 PM
transmission slipping pam01ml320 W163 M-Class 6 07-16-2007 01:52 PM
Slipping Transmission gpotgiet@absamail.co.za W126 S,SE,SEC,SEL,SD,SDL Class 7 05-01-2006 01:58 AM
Transmission slipping? washington dc ML W163 M-Class 23 11-08-2005 05:59 PM
slipping transmission W140Gill W140 S-Class 0 05-29-2003 04:46 AM
