Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-15-2008, 01:51 AM   #1 (permalink)
Date registered: Apr 2008
c180 bad idle when cold
w203 anyone else have this problem? bad idle for a few minutes when first started cold. (every day) will some times stall when small amount of throttle used. Changed maf for new one still the same... small amount of oil on plug at front of engine, on cam solenoid thing (large round thing)..but oil does not go into loom,cleaned connections there. Some times at intersections when hot or cold, i go to drive off i have no power.. only idle.. car can idle across the road i then switch it off then restart and then away we go.
milo16d is offline   Reply With Quote
Old 04-30-2008, 03:25 AM   #2 (permalink)
Vehicle: 2005 C Sport
Hi,
I live in Finland and haven't had that problem with mine even on the really cold days and I haven't plugged it in. Once or twice it has been kind of weird on the start up in the cold if it has been sitting a couple days without use but other than that there's never been an issue.
jas_rho is offline   Reply With Quote
cold start and bad idle list benzacura W201 190E, D-Class 0 10-23-2006 05:07 PM
C180 normal idle revs fouskos W202 C-Class 2 10-20-2006 04:42 AM
Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 10 09-26-2006 12:33 PM
Merc C180 Poor Cold Start dmc1000 W203 C-Class 1 09-06-2006 04:37 PM
C180 idle control mercmender W202 C-Class 0 06-23-2005 10:22 AM
