Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W203 C-Class
Old 04-14-2008, 06:25 PM   #1 (permalink)
Date registered: Mar 2008
air conditioer, clicking sound, a problem?
Hi,
I've currently got my c180 (2001) in at the workshop getting repaired due to some electrical issues (power comes on then off every 30 seconds).
Anyway I was just wondering if I should ask them to have a look at my air conditioner also. When I've been driving for a period of 30 minutes or more with the air conditioner on I hear a clicking sound when I'm accelerating. The sounds appears if it's coming from the center console. By this time the center console feels like a fridge, so the first few times this occurred i figured it was just the air conditioner doing it's thing. Should i be concerned? Might i add it's really annoying when you dont have music playing.
Thanks,
writ3r.
writ3r is offline   Reply With Quote
Old 04-14-2008, 10:45 PM   #2 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
There's a lot of valves in the dash that control the A/C. What happens, and this happens on any car, is the valve is trying to open or close and the valve is damaged, could be a stripped gear, not exactly sure on an MB but it's typical. Find the bad valve and replace.
Old 04-15-2008, 06:58 PM   #3 (permalink)
Generally is this expensive? Since my car is in getting fixed under a warranty claim I might as well ask?
EDIT: Just in case for some reason they wouldn't want to fix it under warranty could it cause any further damage? I tend to be lazy when it comes to taking my car in to get things fixed lol.
Thanks,
writ3r.
Old 04-15-2008, 10:36 PM   #4 (permalink)
BenzWorld W203 Host
It's not dangerous other than your heating/ac won't work properly and it's more of a comfort thing. If you can get it fixed under warranty might as well do it, enjoy the loaner. As for expense, it's not the actuator motors as they are called that's expensive (about $100 each), it's the labor to get to it, some are easier to get to than others. If you want more details I have them on my website but here's a link - http://www.buellwinkle.com/W203HVAC.pdf
Old 04-16-2008, 01:54 AM   #5 (permalink)
oh yep, thanks.
Old 04-16-2008, 11:34 PM   #6 (permalink)
Date registered: Apr 2008
Vehicle: 2005 C230 SS
Probably the stepper motor:
A/C - Ticking Noise From Dash
Date: January 30, 2007
Order No.: P-B-83.00/79a
Supersedes: P-B-83.00/79 dated August 15, 2006
Group: 83
Revision History
Revision Date Purpose
a 1/30/07 Warranty Information Added
- 8/15/06 Initial issue
SUBJECT:
Model203.040/061/064/065/081/084/261/264/281/284/740/74E
Equipped with C-ACC, Option Code 581
Instructions for Replacement of Right Footwell Flap Stepper Motor (M2/11)
If you receive customer reports in the above model vehicles of a ticking noise coming from the area of the instrument panel the cause could be a damaged stepper motor lever arm. The noise may be created by the hex shaped drive shaft of the motor turning in the fractured lever. Updated lever arms are available and it is not necessary to replace the footwell stepper motor.
1. Remove stepper motor for right footwell flap, refer to WIS document AR83.10-P-2007P.
2. Remove and inspect lever arm.
3. If damaged, replace with new updated lever (Figure 1) available separately in kit A203 830 00 33 64.
NOTE: During the installation of the lever do not turn the actuator motor to the correct position by hand, as this could damage the unit. Synchronization will provide the correct adjustment.
Says it's a two hour job, the plastic piece (stepper arm) is cheap.
steveaustin is offline   Reply With Quote
Old 07-02-2008, 02:11 PM   #7 (permalink)
Date registered: Jan 2008
Vehicle: 2003 c240
OK...so this stupid stepper arm is broken, not covered by the extended warranty because it's "not mechanical."
how do i break the motor so that the whole thing is covered?
stephiev13 is offline   Reply With Quote
Old 11-22-2008, 02:02 PM   #8 (permalink)
Date registered: Nov 2008
wonder why it broke in the first place and can you expect to have another broken one with the same motor installed?
1aviator is offline   Reply With Quote
Old 11-26-2008, 08:08 PM   #9 (permalink)
STEPPER ARM INFO
hi someone can tell me where I can see the document AR83.10-P-2007P(FROM STEVEAUSTIN) for repair the stepper arm IN MY C320 2002.
thanks AAA +++
wwwiiilll is offline   Reply With Quote
Clicking Sound?? Benza W163 M-Class 12 08-28-2008 06:23 AM
Clicking Sound olat320 W163 M-Class 6 04-15-2008 09:55 PM
clicking sound? lilbilly11 W126 S,SE,SEC,SEL,SD,SDL Class 7 12-26-2006 02:18 PM
oh oh: clicking sound on take off... 560DBleu R129 SL Class 3 09-26-2005 08:46 AM
Clicking Sound Benza W163 M-Class 1 03-29-2004 10:05 AM
