» Site Navigation » Other Sites
» Network Links
04-14-2008, 07:49 AM
#1 (permalink )
Date registered: Mar 2006
Vehicle: 2006 C230 Sedan
2006 - 2007 C230 DIY Oil Change
This procedure also works for 2001 2002 2003 2004 2005 2006 2007 : C240, C280, C320, C350 & C32
PDF file of the DIY oil change procedure:
Brian Richardson
Jupiter, FL
2006 Mercedes Benz C230 with 6-speed manual
1997 Plymouth Prowler with Matching Trailer
2003 Mercedes Benz C230 Kompressor (Sold)
1993 Mitsubishi 3000GT VR-4 (sold)
04-14-2008, 01:33 PM
#2 (permalink )
Date registered: Apr 2008
Vehicle: 2007 c230 sport
Thank's Very help full and very detailed.
05-03-2008, 01:35 PM
#3 (permalink )
Date registered: May 2008
What weight oil? I've heard both 0w40 and 5w30.
09-09-2008, 06:59 AM
#4 (permalink )
Date registered: May 2005
Vehicle: C320W
DIY Oil Change
Originally Posted by
spoons This procedure also works for 2001 2002 2003 2004 2005 2006 2007 : C240, C280, C320, C350 & C32
Excellent work "Spoons". Thank you. Do you purchase your oil filter's from the dealer or do you shop online? If online, can you recommend a site? Can you recommend a site for the oil extractor? Thanks again.
09-09-2008, 11:54 AM
#5 (permalink )
Date registered: Dec 2006
Vehicle: 04/C230K SportSedan Blk/Blk, 08/C300 SportSedan MarsRed/PremiumII,18"AMG
Spoon,
Where did you get your oil extractor and for how much? (Best looking than most that I've seen). Excellent DYI for many of us. Thanks
09-09-2008, 04:24 PM
#6 (permalink )
Date registered: Jul 2008
Vehicle: 2005 C230 K
Nice.. I was wondering where I seen an extractor like that at before now I remember.. I work right across the street from Grainger that sells them
Fleet & Vehicle Maintenance > Lubricants > Fluid Evacuator > Fluid Evacuator,Manual : Grainger Industrial Supply
Now using the extractor method, is it better then the ol fashion drain from pan? Will the extractor actually remove all the old oil and possible debri if any from the oil pan?
09-09-2008, 08:41 PM
#7 (permalink )
Date registered: Jun 2008
Vehicle: 2005 C230
Hot engine or cold engine when you sucked it up?
09-09-2008, 09:56 PM
#8 (permalink )
Date registered: Aug 2008
how close is this to the 2005 c230 change?
09-10-2008, 12:15 PM
#9 (permalink )
MelloC230
Thanks a lot
09-10-2008, 12:43 PM
#10 (permalink )
Vehicle: 1997 E420
Just wondering - if I read that correctly, this seems to imply this engine has an electric oil pump. Which other engines have electric pumps? Also wondering why they went this way?
Thread Tools Display Modes Linear Mode
